Rod Weight
  • Rusty
    • 18953
    Rod Weight
    Chaps, how does the weight of Scat rods compare to standard ABY rods and also to more expensive rods like Arrow etc?
    Some ramblings:-
    I'm looking at rebuilding the bottom end on mine with lightened 7A flywheel (7 to 8kg) and possibly a lighter front pulley, either 3B (minimal weight change) or custom steel (preferred option but I'll need advice on that from BDB after a reading recent thread by Tonks4x4).
    I'm considering leaving the standard rods in there as they'll take my k24 setup without problems so there's no worries there and that'll save me £250 min. Also, should I ever go mad on power then I'd need to get a new clutch and would possibly go Fidanza flywheel so would need to have it balanced all over again anyway and could replace the rods then. Would prefer to spend the money elsewhere for now, possibly on having the crank lightened a bit (I know that's a bit funny on a steel flywheel but it all helps) and so was wondering if there were any other advantages with rods such as light weight over standard... unfortunatley Titanium rods are out of the question
    Another option is to go to 82mm pistons on a slight overbore and thus getting a little more capacity although I'm under the impression this would cost more than the rods so might be better to just leave it... block has done 165k though so should need honing at least.
  • Rusty
    • 18953
    Come on you lot, there are enough sets of Scat rods out there for someone to post up the weight at least
    • mcandmar
      • Apr 2004
      • 5118
      If your pulling the bottom end apart it would be silly not to IMO. It may save you £250 now but it will cost you that in bearings/gaskets/and time to fit them in the future. Suppose you pick up an RS2 turbo a few months from now, you will be kicking yourself for not fitting them
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        SS
        • Pembo
          • Aug 2004
          • 295
          DO NOT save yourself £250!
          ..and this was with K24 with a 34mm restrictor.
          Pembo
          quattro - Original 4WD rallying
          Rally Car photos
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            sorry,didnt weigh them before i used them!
            • BRY
              • 3755
              Aren't the weights on the outside of the box?
              I haven't got any left BTW.
              • Flat on my back
                • Jan 2007
                • 2449
                I'll weigh one tomorrow on a proper balance, only gives end weights on the box.
                Carlos.
                • Rusty
                  • 18953
                  Pembo, was that not the 3B though? ABY rods are ok for 400ftlbs. If i go for a bigger turbo then I need to do some re-balancing for a new clutch anyway so not too worried.
                    3B rods are stonger than ABY
                    As confirmed by Mihnea at MRC, it's on a thread on the forum.
                    • Rusty
                      • 18953
                      Just read on Ebay that the H section rods on there with ARP bolts are 570g each.
                      • Rusty
                        • 18953
                        Hmmm, not too sure what to do now. Suppose I'll just have to go without food and save for some Scats (better not tell too many people that!)... at least I'll fit the Recaro better
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Weigh each one carl if your scales are really good, just interested like
                          @Andy pay now not later
                          Chef
                          • jade
                            • Jan 2005
                            • 1811
                            I have weighted all 5 with grease they are all 580g
                            RS 2 580HP
                            • Rusty
                              • 18953
                              Hmmm, it looks like once again the forum is going to encourage me to do things properly and spend lots on the old girl
                              Cheers for the weights. Just need to compare it to a stanadard one now.
