lot of people drive 350-400 hp on distributor and stock ignition sistem ...but if you are on high revs , 1.7 bar of boost, there are only one spark hop is enough to destroy rods..
my rods bend at stock engine on 0.5 bar of boost ... what are we talking about?
this distributor are only good because they have hall sensor , and you can use them in AAN/ABY aplication...
if you asking to me...
1. 3B sistem of ignition are more than 20 years old tehnology
2. the sistem like AAN are today in new cars.. each coil on each spark.
different between 3B and AAN , are like heven and hell...
I have AAN sistem in my audi 200 20v which was 3B before.. I done loon swap and everithing looks like OEM.. now I will do one more swap from 3b to aan , on friends 200 20v , and friend from Serbija drive his car to me , to do the same... why ? because it is better...
if will somebody want to do swap, they can contact , and I will help them, and if you want I can come to your home and do the swap.. I will help to everibody ... just kick this 3B sistem , and ECU in the garbage ...
some tuners don't wont to do remap if you have 3B sistem, there are allways some problem with them..
