For my project I've just ensured that the width is not wider than original, as has been suggested in the past when using the p/n. This obviously doesn't reduce risk of spark hop, but it makes sure that the risk is not increased! I'm interested to see what alternative coils you find.
when i checked my rotor arm the other day there seemed to be a resistor in line. no idea why it's there but would it reduce the final power of the spark at the plug and may be not getting the full benafit of the uprated coil. if you put more voltage through it could it result in burning out the rotor arm . and may be worst case sending spark to wrong cylinder i may be talking coplete ******** but this is how my mind works i am afrade. perhaps a different rotor arm may have to go with the uprated coil.
never set your expectations to high that way you are never disapointed
