Uprated single coil for 3B?
  • Jonas_R
    • 3781
    • Country: Denmark
    After the discussions about spark hop etc. It was mentioned to use a uprated single coil for the 3B to avoid this.
    But what choices is out there for an uprated version?
    Also what is required besides an uprated single coil?
    Any suggestions, inputs etc. are very welcome
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • S2_Dave
    • Aug 2005
    • 456
    SQ surely is an option?
    For my project I've just ensured that the width is not wider than original, as has been suggested in the past when using the p/n. This obviously doesn't reduce risk of spark hop, but it makes sure that the risk is not increased! I'm interested to see what alternative coils you find.
    David
    '91 3B S2 Coupe
    • S2_Dave
      • Aug 2005
      • 456
      whoops
      David
      '91 3B S2 Coupe
      • Jonas_R
        • 3781
        • Country: Denmark
        Did not think of that, but yeah SQ could be an option
        I have emailed MSD and 034motorsport asking about uprated coils.
        I also checked my rotorarm and it is the narrow type, just to decrease chance of spark hop.
        • urquattro-island
          • Mar 2006
          • 1915
          • Home: Norway Current: Iceland
          Hi
          any partnr on the sq part??? this means sportquattro i think??? :iamwithstupid:
          japanischer industriabfall nein danke!!
          www.rackeltrim.se Icelandic Division
          • urquattro-island
            • Mar 2006
            • 1915
            eeeh
            that smiley sign did not come out right sorry :Angel_anim:
            • Jonas_R
              • 3781
              • Country: Denmark
              Yup part no. 443 905 105 A price around 220 euro without VAT.
              Considering getting one
              • urquattro-island
                • Mar 2006
                • 1915
                hmm
                i must consider this as well, any info on how much better it is??
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  I have no idea if it is even better. It is also used on the audi 100 with the MC engine 2.2 Turbo with 165 bhp.
                  Perhaps I can get a used one cheap on ebay and then compare specs
                  • Acidburn
                    • 13459
                    Be good to see how they compare and how easy it is to find one.
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      Yeah dont seem to be easy to find one right now
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        Some news, got an email back from 034motorsport:
                        You will need this coil and 1 plug wire end for the coil lead...
                        Coil: http://www.034motorsport.com/product...roducts_id=277
                        Plug wire end: http://www.034motorsport.com/product...products_id=41
                        Any thoughts on this item?
                        • denniselbows
                          • 740
                          when i checked my rotor arm the other day there seemed to be a resistor in line. no idea why it's there but would it reduce the final power of the spark at the plug and may be not getting the full benafit of the uprated coil. if you put more voltage through it could it result in burning out the rotor arm . and may be worst case sending spark to wrong cylinder i may be talking coplete ******** but this is how my mind works i am afrade. perhaps a different rotor arm may have to go with the uprated coil.
                          never set your expectations to high that way you are never disapointed
