dest,have you really measured your car's weight?S2 and RS2 avant dont have a whole lot differences to have too much weight difference and it seems that i have never found an avant fully equiped that weighs less than 1600-1650Kg with a driver.Mine weighs 1780 with me in(80Kg) but i do carry a nice set of tools and couple of fluid bottles,fire extinguishers etc.
The problem with these avants is the weight if you ask me,and only solution is more power,as eventually a SM flywheel will be gotten used to and also the RS2 route,is not the cheaper choice as the rs2 turbo is ridicusly expensive,when there are lots of newer and better turbos to select from.I agree that this is not a car to have it striped so,just put on some more power and you will feel the difference.
Actually a thing that i wanted to mention as well is that since i replaced the diff mount with the apicol unit,the car doesnt really dip on the rear end anymore and although it seems to clime the Kms at the same rate,you dont actually feel the acceleration the same way as before.Kick seems less obvious,but the Kms tell me that this is misleading,as it goes fast anyway.So there are many factors that can make you 'feel'less kick there
This is exactly why i love the S2!
