Can you make an S2 "feel" quicker?
  • A80Avant
    • 10873
    • Country: Greece
    #31
    dest,have you really measured your car's weight?S2 and RS2 avant dont have a whole lot differences to have too much weight difference and it seems that i have never found an avant fully equiped that weighs less than 1600-1650Kg with a driver.Mine weighs 1780 with me in(80Kg) but i do carry a nice set of tools and couple of fluid bottles,fire extinguishers etc.
    The problem with these avants is the weight if you ask me,and only solution is more power,as eventually a SM flywheel will be gotten used to and also the RS2 route,is not the cheaper choice as the rs2 turbo is ridicusly expensive,when there are lots of newer and better turbos to select from.I agree that this is not a car to have it striped so,just put on some more power and you will feel the difference.
    Actually a thing that i wanted to mention as well is that since i replaced the diff mount with the apicol unit,the car doesnt really dip on the rear end anymore and although it seems to clime the Kms at the same rate,you dont actually feel the acceleration the same way as before.Kick seems less obvious,but the Kms tell me that this is misleading,as it goes fast anyway.So there are many factors that can make you 'feel'less kick there
    • hiltoa
      • 1060
      • Home: United Nations Current: England
      #32
      Originally posted by nip
      lol dest like the multiple answers, what does urs boost at mine boosts at 23 psi, its 289bhp torque is 330, it feels well lively also have removed the cats full s/s system.
      i agree with paul could be a leak somewhere,
      I can second that - nips car is pretty nippy having test driven it before he bought it...
      As for dest - IMHO the nature of performance Audis tends to mask their acceleration, and it gets 'worse' the more modern the Audi. I tested an A6 2.7tt last week and the speedo was the only thing telling me how quick the thing was. A bit dull really. The only solution is to talk to MRC and get your wallet out, or switch to something less refined...
      Nothing feels fast for long...
      2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
      • KaraK
        • 328
        Originally posted by Sonic
        This is exactly why i love the S2!
        You can mash your foot and be doing silly speeds pretty quickly, throw it hard into corners without a worry in the world, whilst sitting in your comfy leather chair with Bach playing softly in the background, without a care in the world - knowing full well that as the impreza behind you drifts away the poor ******* driving it will have blood pouring from his ears
        ahh so its a car for old farts then?
        Haynes Manual:As described in Chapter 7...
        Translation:That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.
          Cheapest way is to run Tesco 99 and possibly a little octane booster.
          Make sure there are ABSOLUTELY NO AIR LEAKS on the boost hoses and importantly the breather system.
          Run the lightest oil you can, 5W50 is as light as I dare go with track, 10W60 is prob. better but road use might allow 10 or 5w40 but the turbo will be under a bit more wear.
          SM flywheel, lightened 1Kg and cleaned up should do the trick.
          Lightweight wheels such as OZ Ultralegerras, and light tyres
          Smallest brakes you can allow, i.e. 314s, standard rears
          Strip all unnecessary weight out, replace heavy armchairs with racing buckets
          Drill the airbox, it makes it sound a lot faster.
          Adjustable DV such as Turbosmart for the same effect.
          Louder exhaust for the same effect.
          Basically what I've done to mine and it feels and sounds rapid enough for now
            #35
            Yeah old farts that don't need 'that' shade of blue paint on a tinny Japanese box with gold pheckin wheels and a 1970's dustbin for a zorst...
              #36
              LOL @ Andy - yours 'feels' fast cos it is fast
                Not really, I'd be suprised if it was any faster than any other Homefried S2 TBH. Have to see how it fares when I can get back on track with the new toys on , new boots on and whatever else comes my way...
                • bluequattro
                  • 2960
                  My daily is a diesel land rover, so walking seems fast!
                  Its the weight penalty of the avant that doesnt help matters.
                  Years ago when i first had a gt coupe i stripped it inside as it leaked in. took rear seats out and all the trim i didnt need. made it much faster.
                  time your car from a standing start and see how it comapres to your previous ones-may be that it is faster but you dont realise because its better built!
                  • nip
                    • Apr 2006
                    • 1786
                    • Home: United Kingdom Current: Abu Dhabi
                    #39
                    thanks hiltoa, but when i bought the car and most probably when you and i test drove it it had a boost leak, i noticed on way home, went to dougs whilst doin a boost test he noticed the jublee clip was knackered, went loads better then
                    • hiltoa
                      • 1060
                      #40
                      Damn! If I had known it had even more kick to it, I'd have definately bought it instead of the A4!
                      • nip
                        • Apr 2006
                        • 1786
                        #41
                        lol mate
                        • shark_90
                          • 1475
                          Originally posted by madwolf_Uk
                          i like that description!
                          Still think that maybe the Coupe's may "feel" quicker than Avant's perhaps, more of a sports car feel being the right shape and all that?
                          The Avant is the epitome of a sporty Audi, I'll have none of this Coupe nonsense
                          1994 Audi S2 Avant - in pieces
                          2006 Skoda Octavia vRS 2.0TFSi - goes fast
                          1985 Audi 90 quattro - is wet
                          Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
                          • dest
                            • 4287
                            Originally posted by K7ERG
                            Remove the cats and fit downpipe/system i found it made a big difference on my URS4.
                            Have you had the car on the rollers to see if the engine is making the power it should with the homefry?
                            Craig
                            Ive not had it on the rollers yet, and am planning on getting the cats removed asap
                            IMO the other cars you mention have inferior characteristics such that they have more inherent lag and off-boost performance that you feel that kick in the back when the turbo finally comes on.
                            The S2 is pretty quiet too...
                            Paul
                            I should obviously state that my Cav was highly modified, which included bigger injectors, front mounted intercooler (standard one does have one atall!), hybrid turbo, EVO5 chip, full 3" system with no cats or centre box, XE inlet cam (gives more torque)
                            Yes, I totally agree the S2 is quiet, mine was near enough silent when I got it, but it is FAR from quiet now
                            Originally posted by Jamo
                            If the S2 feels slow don't get a S4 as they feel slower because of the smoothness
                            The problem normally isn't the car feel slows, the problem is your now used to how fast the car is!
                            That could be part of it.
                            I also strongly feel it doesnt help when you have previously owned other cars that have very good performance, as naturally you compare them.
                            Having been in my car (although it wasnt homefried at the time), did you feel it was running heathly in comparison to others you have been in?
                            Got to love multiquote lol!
                            Mine is showing ~17psi on full boost, which I have been told is alittle low, but I havent got a clue what is causing it!!
                            Your figures are pretty much exactly the same as my Cav had, so to me that proves I CAN acheive them. But, I guess even with the same figures, it will also depend on how its delivered which makes it "feel" fast or not
                            Originally posted by Fat Audi 80
                            I struggle to believe an S2 with 280 bhp and 300ftlbs can feel slow to ANYONE.
                            Cheers,
                            Steve.
                            As above, I strongly think that what you have owned and are comparing it to can make ANY car feel slower or faster!
                            I dont want a car that sends me to sleep....... I want abit of crash bang wallop!
                            Something that sounds nice, (I will admit now that mine DOES sound AWESOME and I love do it!) and goes well when you want it to.
                            I want a car that makes me sit up and take notice, something that awakens my senses, not sends them drifting to sleep as I aimlessly waft along!
                            Another thing I was thinking, in relation to what I said above... all you that love the performance of your S2, have you owned anything previously that is FASTER?
                            • KaraK
                              • 328
                              ahh.. so youi've seen my car then
                              I'm only messing... me and sonic have have had many a long conversation about the relative merits of our cars. Still need to get it as fast as his rather rapid s2 however!
                              • nip
                                • Apr 2006
                                • 1786
                                #45
                                dest do any of ur muckers have cossies or anything fast if so see how ur s2 competes against them, it will give you a rough idea
