If you're only running 0.4 bar of boost I would say the WGFV is not working, a boost leak of that magnitude would cause the engine to cut out at WOT. Find that problem first. A bad turbo would burn oil, smoke a lot or make a loud whistling noise. What the f*** is a "tired" turbo?? (ah, poor thing , its been working too hard, needs a nice lie down, feet up, drinky poos..)
A few people have fitted RS2 turbos with no other mods, you get more top end but a tendency to run lean, you really need all the other bits and a proper remap.
. They do tend to get very very tired even pro plus doesnt work!! Sometimes they need horlicks to bring them up to scratch... Another great tip from a top tuner not mentioning the obvious.!!
Think you may be getting confused and you're certainly confusing us on here. If you have a proper boost guage then it will only measure boost, boost being the pressure above atmospheric pressure! If your measuring 1.4bar then that's the boost you're getting from the turbo. Would be 2.4bar if you add atmospheric ala the digital guages fitted to the S4s and S6s.
