Can anybody tell me what the difference is between the ABY / RS2 oil pump and the AAT / AET diesel oil pump?
Oil pumps
If you need pictures of an aby i have one...or two, pumps that is.
Pictures, as many as you like...Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.uk -
You're barking down the wrong rabbit hole
The AAN and ABY shared the same oil pump. The RS2 oil pump was the AAR oil pump. Presumably the diesel pumps flowed more oil but I can not confirm that.
Read this: Oil Pump, Temperature Sender, Pressure Relief Valve Info:
Quote from provided link:
Read this: http://forums.quattroworld.com/s4s6/msgs/93029.phtml
''Note: The ADU in the RS2 originally used the 054115105D oil pump from the AAR 10V five cylinder gasoline engine instead of the more common 054115105E that the AAN and ABY use. However, the 054115105D was dropped on Jan.11, 2002 in favour of the AAN/ABY oil pump (the 054115105E)''
So NG/AAR/ABY/ADU/AAN are the same 054115105D/054115105E
The question I have is are diesel oil pumps ok to use on 3b style cars, eg ok at petrol rpms? They are easier to get hold off....
Sent from my Moto G (5) using Tapatalk
