Homefried ECU rocks......
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    #91
    OK been for a drive around the village and I have learnt the following (in a homefried ABY): -
    1. Max mechanical boost with a stock spring and factory position nut = 0.4 bar (in gears 1 - 4)
    2. Gears 5 & 6 are not possible in my village as the speed bumps tend to launch you skywards
    3. The WGFV is not easy to disconnect in the dark
    4. Don't reconnect the WGFV in the dark in a hot engine with a very hot turbo
    5. My wife gets mad when I go from the study to the car and drive off without telling her what/when/why/where/how
    Cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
      @ James.
      Just do me a favour, go out there, pull the MAF connector off spray it with switch cleaner if you have some and wiggle it on and off a few times and take it for a drive. Let us know if its still overboosting.
      • Fat Audi 80
        • 10547
        I am wondering if James has an electrical fault too...
        The Perfectionist
        • johne
          • Apr 2007
          • 1405
          Si, you beat me to it. Unlike Paul I don't have the oats option so I too have been out around with the wastegate valve disconnected................I'm waiting until tomorrow morning to reconnect it
          Like Si I have an unmodified ABY other than Homefries fitted. Max boost I saw was 6 PSI, which equals 0.4 bar - so there it is.
          Paul, you should be ready to rejoin the debate..........
          John
          • JamesHarrold
            • Feb 2008
            • 245
            Hi guys....WOW
            I have only been away a couple of hours....!
            Very interesting though, I am having a day on the car on Monday, so will be reporting my findings.
            Just a quickie though....My car boosts at 0.6 bar with the wgfv disconnected. It only boosts at 0.4 with the screw fully out (standard spring)
            Will try spraying the maf connector over the weekend...
            Thanks for all the help guys, much appreciated.
            ps @johne & HPmuirt....I owe you both some fuel!
            • johne
              • Apr 2007
              • 1405
              Fuel no problem, been enjoying the debate and happy to have an excuse to "floor it"
              Only problem is that sort of driving ruins my reputation for driving like a nun as I'm the only one on here to achieve 30 mpg with Homefries and 95 unleaded
              John
              • JamesHarrold
                • Feb 2008
                • 245
                Hi John...
                You are on for a challenge of fuel economy when I get my bloody car working properly.
                Am looking forward to getting to the bottom of it so have got all day in the workshop on Monday.
                Anything else worth checking. Am going to go to town on the leak test and try and rule that out if it holds pressure.
                Would a leak cause a rough idle?
                James
                • johne
                  • Apr 2007
                  • 1405
                  Not an expert on this area but for me rough idle has been cured by cleaning the idle stabilisation valve with carb cleaner
                  Any leak is a problem because the engine won't be getting the oxygen the MAF has told the ECU it is so the fuelling will be wrong
                  • T2Andy
                    • 1903
                    Have you cleaned the wire mesh in the flame trap ,mine was clogged with carbon
                    which doesnt help with cranckcase breathing.
                    I also cleaned the air flow censor on the inlet mani which all helps smooth running.
                    • JamesHarrold
                      • Feb 2008
                      • 245
                      Thanks for putting it in simple terms John...So it really doesnt need much of a leak to affect things then...
                      As far as the idle goes, I bought a new ISV today (god, this is getting expensive!)
                      and it made no difference at all...car still stalls at roundabouts or whenever you coast to a stop with your foot on the clutch.
                      James
                      ps now off to bed, thanks for all the info though guys, will resume tomorrow
                      • JamesHarrold
                        • Feb 2008
                        • 245
                        Thanks Andy...will add it to the list to do on monday
                        James
                        • T2Andy
                          • 1903
                          Hope you get it sorted mate ,ive had similer probs but they would come and go
                          mine runs alot better now ive changed the exhaust and cats.
                          • JamesHarrold
                            • Feb 2008
                            • 245
                            Hi Andy...
                            Yep, cats were changed when I bought the car....they were totally blocked and it was not boosting at all....when put on the dyno it was producing 102bhp...!
                            As i have said, I am spending ALL day and night in the workshop tommorrow, so any ideas as to what to check would be most appreciated.... I have a few things written down.
                            Check plugs and @ 30lb/ft
                            Leak test EVERYTHING
                            Check and clean MAF connection
                            Check flame trap mesh and clean.
                            Clean (new) ISV with wd40
                            Anything else i could check/try...?
                            James
                            ps, did the output test from SJM website today and all components seem to be working fine. (should do as the wgfv and isv are brand new)
                            • PeteRR
                              • 1326
                              Originally posted by JamesHarrold
                              ....Check plugs and @ 30lb/ft....
                              I hope you mean 30 Nm James!
                              • JamesHarrold
                                • Feb 2008
                                • 245
                                Yep..... Sorry Pete...
                                Any other suggestions?
                                James
