FYI for anybody fitting a new oil pump
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by Jamo
    I haven't bought the ICE drive, James has, it allows the pump to rev higher and not slip at higher revs maintaining oil pressure.
    Think Terrybullwon is going for a high redline
    Thats right Jamo
    8200rpm is possible
    Chef
    • Ross
      • Aug 2005
      • 3399
      Interesting! Not sure that would translate to a failed bearing on only one cylinder though?
      I do have my lovely £250 ABY oil pump in the garage, was thinking about making an ornament from it.
        Have it polished Ross, then sell it to flavour flav - Yeeeeeeeah booooooy!
        • GazzaG60
          • 4133
          if its made in korea ross id check its got a flat seal surface.
          • Flat on my back
            • Jan 2007
            • 2449
            Here's another one for you...
            Just checked both of my new aby pumps...one rotates the other doesn't...
            HMF...
            Carlos.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #21
              I've kept my original pump. Tried and tested for 180k miles.
              SS
              • Flat on my back
                • Jan 2007
                • 2449
                The results.
                Just split the dodgey pump.
                Shows signs of small metal particles and surface rust...will be fully cleaning it.
                Carlos.
                • mcandmar
                  • Apr 2004
                  • 5118
                  Pump looked fine out of the box, it was only when i dismantled it to lube everything i found the grit. You can feel it when you rub it between your fingers, not good.
                  Mark.
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Yours don't look as bad, was it made in Korea too?
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      Both my pumps are stamped 'korea'...i'll be spliting that one as well.
                      Looks like fine casting sand?
                      P.S. anyone know the torque for the screws on the inner plate now i've stripped it?
                      Carlos.
                      • mcandmar
                        • Apr 2004
                        • 5118
                        I think your right, thats exactly what it is. Looks like its soft, but feels like sand.
                        No idea on the torques, i couldn't find any reference. Mine had a line drawn through them with a felt tipped pen, i just cranked them by feel then made sure the lines match up. Oh and a little dab of red loctite to help me sleep at night
                        • Flat on my back
                          • Jan 2007
                          • 2449
                          Been recommended this one.
                          Carlos.
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            My Father came up with a really good expaination when i could not find the torque settings for the backing plate.. Jst do them up tight basiclly
                            Chef
                              #29
                              Why cant we get oil pumps built in Germany ?
                              If I wanted ****ing Korean parts I'd have bought a ****ing Hyundai or some other pissashid Korean crap.
                              PS - I am NOT racist - I just have no time for Japanese or Korean cars - never have - since I was a nipper I could tell they had as much soul as Dolly Parton.
                              • volcano rs
                                • Jun 2005
                                • 2265
                                Originally posted by GazzaG60
                                my new oil pump would not fit properly. it seeped oil from the edges, i also had to file down a few bits to fit the pulley guard back on.
                                made in korea stamped on it.
                                double check the front seal new one comes with a dummy seal ( well mine did anyway)
