2111 Fault Code Help Please
  • S2Addict
    • 110
    No such luck, got in late today.
    Tried firing up and hey presto she started up fine.
    Swithched her off and again she refused to start
    Tried pulling the codes again and same old code of 2111??
    When she started up, I left her running for around 15min before switching off and trying again.
    I swore a couple of times, kicked my cat and then kicked my neighbour!
    Gave up had a couple of shots of Vodka and have given in to the fact that I won't be making ADI
      Dont worry about the 2221, its a red herring, you will always get that code when the engine is not running (as about 5 other people have told you )
      My money is on the ignition switch.
      • rs200
        • May 2009
        • 1398
        • Home: Croatia
        hy people..
        now I have same problem but engine are running fine and work fine, but I can't get over 0.5 bar of boost , and fault code said 2111 problem.
        but it's not , because I have check all wires and sensor are replaced. there are no boost leak (I done boost leak test) , something else block boost on 0.5 bar.
        it is audi 200 20v 3b stock engine..
        please help... thanks...
        • driftin jo
          • Sep 2007
          • 2222
          Originally posted by rs200
          hy people..
          This is not the same problem .
          This sounds like your waste gate frequency valve (N75) is dead.
          • rs200
            • May 2009
            • 1398
            • Home: Croatia
            #20
            yes I know that have no sense , but it happened... I have messured the N75 and its OK, could N75 have good resistance (ohm) but not work proppetly ?
            thanks...
            • driftin jo
              • Sep 2007
              • 2222
              thanks...
              YES.
              • rs200
                • May 2009
                • 1398
                • Home: Croatia
                #22
                hm... now I go to check one more time how much ohm have to be , and it have 32.8 ohm. that is ok...
                well did N75 have to "klik" all the time , or only when it is disconected or conected. because when I disconect him they do 1 "klik" , and conect they do another "klik". is that good .. or they have to "kliking" all the time? when engine running at idle..
                thanks
                • driftin jo
                  • Sep 2007
                  • 2222
                  Sounds like it could be OK, but you can not be sure.
                  You could try disconnecting the hose to the waste gate and try driving it to see if the boost goes up , this will let you know if the N75 is dead . If you take the hose off only go WOT until you prove have more than the .5 bar boost that you have now then back off so as not to get over boost . Do not drive at WOT more than you need to .
                  • rs200
                    • May 2009
                    • 1398
                    • Home: Croatia
                    #24
                    well I don't know what mean WOT? sorry , but can you tel me?
                    and I understand what will happened if I block the lowest pipe on WGFV. the boost will rise in 1. gear to 1bar . but I don't know what I will proof with that? broken N75?
                    I test it before few days N75 have 3 pipes and 2 of them are passable , and 1 are blocked if you try to blow in them... is that a good sign or not? I thing it is...
                    and one more thing: when drive the car in 2. or 3. gear and slowly accelerating in one moment between 2000-3500 rpm , car don't accelerate linear.. some strange filling is like , they loose a power , or something like whole ... I don't know how to explain that filling to you...they lose anger on gas pedal..
                    and after 3500 rpm it go much better, and produce 0.5 bar... but that strange filling is not all the time . sometimes is sometimes not... could that help you for ?
                    filling is like that turbo don't give enough air or fuel are missing...
                    thanks
                    • driftin jo
                      • Sep 2007
                      • 2222
                      WOT = wide open throttle .
                      If the boost is going up with the pipe removed from the waste gate then it is most likely the N75 dead.
                      It does not prove for certain that the N75 is dead as the ECU could be in limp mode for some other reason and this would only allow low boost, (spring only) .
                      It could be the connector to the mass are flow sensor , try cleaning the connector and disconnect the battery to reset the ECU.
                      • rs200
                        • May 2009
                        • 1398
                        • Home: Croatia
                        #26
                        you wouldn't belive but now I go outside and block this pipe , and do few kilometers...
                        they want to produce high and quick boost . I get it to 0.8 bar in 2. gear, they want to go further but I stop in last moment... in 1. gear I didn't try...
                        so what we find out? broken N75?
                        spring in waste gate is fine... I check them before few days..
                        tomorow I will replace the N75. than we will find out , but I'm 99.9% sure that this N75 is good..
                        what other thing can caus that problem? why I have this fak'n 2111 fault code?
                        • driftin jo
                          • Sep 2007
                          • 2222
                          Do you have this code 2111 with the engine running ?
                          It will always show 2111 if engine is stopped.
                          If you get it with the engine running then the sensor is bad.
                          • driftin jo
                            • Sep 2007
                            • 2222
                            If you have 2111 code when engine is running then this is your problem as the ECU will go in to limp mode .
                            • rs200
                              • May 2009
                              • 1398
                              • Home: Croatia
                              #29
                              ahhhhhaaaaaaaa... no I didn't try it when engine is running... than I don't have problem with sensor because I always try blink code when engine was off .
                              thanks.. because I know that engine could not start if rpm sensor where bad...
                              hahahh , than we have only boost problem...
                              hm... than only maf can cause low boost problem... he is the only thing that I didn't check...
                              tomorow is a D day, must find the problem...
                              driftin jo , thanks for help... without you ... I don't know...BIGGGGG THANKS...
                              • LHD_Kid
                                • May 2006
                                • 3695
                                #30
                                ahhhhhaaaaaaaa... no I didn't try it when engine is running... than I don't have problem with sensor because I always try blink code when engine was off ...
                                D'oh
