rs2 parts on homefried s2
  • valjo
    • 1110
    • Country: Latvia
    hi!
    i have audi s2 aby with homefries. i wonder what will happend if i put rs2 ehoust mainfold and downpipe to original s2 setup. will ecu adopt to new hardware?
    what about lag etc?
    thanks
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
  • lind4hl
    • Jul 2008
    • 2465
    i think you not will gain so much extra hp on rs2 exhaust, why not an 3" directly and a remap? it will work without a remap, but to get the last bhp you will need it.
    • valjo
      • 1110
      • Country: Latvia
      because i will go for rs2 tehnic but in the middle time i wonder if i could use parts i allready have at home
      Audi Coupe S2 1993
      Audi V8 4.2 1993
      Audi cabrio 1998
      • lind4hl
        • Jul 2008
        • 2465
        the car will work with rs2 exhaust without remap, that´s for sure
        • Jonas_R
          • 3781
          • Country: Denmark
          If you are going to run a RS2 turbo as well, then I would wait with the installation of the downpipe and EM.
          It takes quite a lot of hours to change the turbo, so why not do downpipe, turbo and EM at once?
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
          • DarrenM
            • Aug 2007
            • 1227
            Im running RS2 turbo and 3"DP & system on a homefry, was gonna wait till i get the injectors & IC before getting it mapped witha 3bar v-map tho. It is laggy but just needs winding up. I'll pull my finger out and get the other bits one day.
              I'm running homefries with RS2 IC, 3" turbo back, samcos, modified airbox. Runs fine when I've had it tested on rolling road. Hoping to keep pushing the Homefries for a while yet too. It ran better with 3" than OE, RS2 IC wasn't such a big change but that's being worked on.
