is the question with the most answers i think.
Depends on if its aby or 3b, the safe answer would be, about 380 ca for both engines, but about 420nm for 3b and 450-500nm for the aby without new internals.
But then again there is always those who have run more power and torque, and gotten away with it, and still do. Know of some from sweden and norway.
Norwegian 10vt running 502hp 607nm on stock internals it lastet the season 2002-2003 almost.
so hey anything goes, if you have money, and arent afraid of work.
I am in the progress of rebuilding a 3B. I´l try to get close to 400 bhp. Will the original pistons hold or do i have to change those as well? The rods are will of course be changed. It´s gonna be used as a daily driver and not a trackmonster.
what is difference between 3b and aby internals? as i know they have same rods and pistons .......
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
400bhp easy for factory pistons and rings.
A good intercooler is highly recommended on such a spec.
High torque levels will need the later RS2 spec big-end bearings and of course forged rods are highly recommended if running high boost levels in the mid range.
The 3B would have left the factory with a paper head gasket... Long since replaced by the superior metal version on late AAN, the ABY and RS2.
Only other thing to be cautious of on the 3B is the dreaded spark hop. Make sure the distributor drivetrain, rotor arm and dissy cap are in full health.
Hi!
I have AAN motor. What I need to change of motor internals to be sure that the motor will not be blow out. I expect to go for 450-500hp.
I read that it's only need to change the rods and pistons for 500hp and motor can work without problems. Is that thru?
you will be pushing it a little at 500 but its there.
i changed the rods and skimmed the piston to lower compression slightly.
i think that a good 420hp is possible from the standard engine including cams and inlet. the work for this and more though is around the exhaust and turbo. get thouse gases out easily to avoid high egt
