NO need for reduced compression on a 400bhp machine IME... Best left to monsters making much more power in the high rpms and where driveability down low is less important.
s2 std engine how much power?
@billman
Well I use JE with no problems with slapping, slightly lesser clearance then quoted and good running in period. The Mahle are good and I know they will take in excess of 600BHP.
The problem with JE is now the price as the weak pound makes them less attractiveAelredComment
Fair nuff - see that now Jamo, but was just concerned about previous comments on a ~400bhp setup.Paul Nugent
the reason i skimmed the piston and not used a thicker gasket were for 3 reasons.
1. i needed the pistons cleaning up somewhat.
2. i had them balanced and weightmatched with the rods.
3. wanted to add a couple of degress up the rpm range with higher boost.
it made the engine a little smoother as i hoped.
if we all did the same this would be the ford rs owners clubComment
What rods and metal gasket do you suggest for 500hp?
Some links?
Thank'sAudi URS4 1992. 2.2L 169kw
www.audiclubserbia.comComment
Best to search the forum - lots of previous threads on this subject... Many choices of rods especially.Paul Nugent
