2871R goes rather nicely...
  • BRY
    • 3755
    #61
    Are you offering generic chips for this setup?
      #62
      I will be - car must have an AFR guage though. Would like to real-time map another one or two - on 98RON next time.
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        #63
        Paul i have already installed a wideband with AFR gauge....
        give me a 2871 and try it
          #64
          'give' ?
          LOL
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            #65
            'give' ?
            LOL
            if you want...
            borrow better
            if you want travel to the north of Spain for holidays or other different something take a 2871 with k26 flange and we will try all the times as you want . later the turbo it´s for you again
            i hope that my 440cc/3bar injectors are enough for this turbo...
              #66
              Rocco - but you have an inferior 3B... I've not got enough experience to attempt a custom map on that yet... it is VERY different from ABY and RS2. Maybe someday...
              • Ca2
                • Apr 2005
                • 2
                #67
                Paul - Is this the 48 Trim version ?
                What about A/R ?
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #68
                  inferior 3B??? stock ABY´s cars are slower in the tracks....than stock 3b ones hehehehe
                  OK Paul understand it, you can tune the chips very well but only with the AAN-ADU,ABY Ecus... not enough experience
                  aniway you have to learn about 3b motronic because there are much more 3b cars in the market
                  • karlblues2
                    • Jul 2004
                    • 402
                    • Home: England Current: Australia
                    #69
                    OK Paul. Just need to understand what else was changed apart from turbo in that car. As you know I have an ABY engined coupe with RS2 injectors, 3 Bar MAP sensor, upgraded Bosch Fuel pump, RS2 Exhaust Manifold and 3" turbo back exhaust. I currently run an MD147 with MRC chipsets. Basically I want to swap out turbo and insert 2871R with a chipset of yours to suit. Is this possible or would I have to retrofit original parts such as S2 injectors and S2 MAP sensor first?
                    Very excited mate
                    Karl
                    Oz
                    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
                    Audi 90 Quattro 20V 1989 7A
                    Audi TTRS 2010 APR stage 2 +
                    Triumph 675 Street Triple R
                      Very excited mate
                      Karl
                      Oz
                      You need to keep the RS2 injectors and 3bar map sensor, infact the RS2 maybe too small from Diesel Des LPG thread as they hit 100% duty cycle.
                      • karlblues2
                        • Jul 2004
                        • 402
                        #71
                        Wow, I thought going from an RS2 stage 3 MD147 turbo to a 2871R would require less, not more fuel especially given I'm currently peaking at 28psi of boost or 2 bar. Or is that irrelevent to what your saying
                        Cheers Jamo
                        Karl
                        Oz
                          #72
                          RS2 injectors (360ccpm) are too small.
                          You could go with Bosch racing greens (440ccpm), but Des opted for Siemens 550ccpm to give loads of headroom - thats what I have mapped with.
                          I'm sure the Bosch 440s would work on this turbo (pretty sure its what 034 use) but I'd need to do them one or two in real-time before having any sort of confidence in chips to post to Australia. Now a real-time mapping session in the land down under would be really nice - hehehhh - who wants to pay for that - awwww please...
                          @Karl - with a set of Siemens 550 injectors, and this chipset of mine you'd be ready to play when the 2871R is fitted. I also advise you keep the cams standard, but I hope you have a mighty big intercooler - and maybe water injection to help with the higher air temps down there in the summertime.
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            #73
                            RS2 injectors are 360ccpm at 3 bar of FPR true Paul?? and the racing bosch greens are 440ccpm at 3 bar FPR too ??? and then it´s more or less the same work with the RS2 injectors with a 4bar FPR than the 440´s with a 3 bar FPR ....???
                              #74
                              No but the ABY/AAN/ADU runs a 4bar FPR - so its not as simple as you think....
                              • Billman
                                • 4129
                                #75
                                This 2871 has an 51-52mm compressor impeller? If yes then i think the 460 is way overestimated or i can run with mine 550 hp then :-)
                                Go Holset or Go RS4
