4bar FPR on stock RS2
  • MarT2
    • 175
    • Country: Spain
    Hi all!
    What could happen if I mount a ABY FPR(4bar) on a stock RS2 (3'8bar)?
    The car can run good? Or I can have any problem with the ECU and the injectors?
    I have more cv and torque?
    Why would you do this?
    you'd need to remap the car as you'd be running rich all the time if you did not.
    If you were doing it and then having the car remapped it would be fine.
      It would run a little richer at WOT - we are talking about a very small change here... Adaptation in cruise will cater for this change.
      • MarT2
        • 175
        • Country: Spain
        Ok Paul! So there is no problem to mount the ABY FPR?
        I buy a RS2 FPR throught ebay, but the seller send me a ABY FPR!!!
        What is WOT? Sorry for my english!
        • GT500
          • Jun 2006
          • 2181
          If you want 561 fault code and a knackered lambda go for it!
          Not the way to gain poer.
          WOT wide open throttle.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • MarT2
            • 175
            • Country: Spain
            Finally I buy the ADU FPR and I will do some test with the 2 FPR's!
            • EspenW
              • Apr 2007
              • 1534
              • Country: Norway
              Going from a 3.8bar to a 4bar FPR will increase the fuel flow by approx 2.5% (square root of the pressure increase). It equals swapping the stock injectors (approx 360cc) with 370cc injectors.
              It will run slightly richer at WOT, but at part throttle, it will be well within the authority range of the OXS system, keeping the AFR around 14.7.
              Note, however, that stock RS2's seem to run pig rich, so making it even richer is not good.
              I run my fuel pressure from 2 to 3.6 bar depending on the mix of petrol an ethanol in the tank.
              1994 80E Avant
              1986 2L Golf 2 on Alcohol
              • M_GORDON
                • Oct 2008
                • 1295
                • Home: Isle of Man Current: Vatican City State
                Jose, test they and talk about.
                I bought one regulable between 3 and 5 and my meca say me that this´s broken...and I must mount my ABY frp another time.
                photobucket SUCKS
                • Knight Rider S4
                  • 3541
                  I am putting together my 3B with the same spec RS2 stuff but i was led to believe that fitting the 7A FPR would suit this set up...Is the 7A FPR not 4 bar?
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                    Yes 7A FPR is also 4bar... It is in the right package for easy upgrade on a 3B fuel rail.
                    3.8bar vs 4bar is in the noise - easily within adaptation limits as stated earlier for an ECU that expects either one...
                    The RS2 and S2 both run quite rich at WOT - factory programming is typically very conservative - to cater for aging of components, fuel quality etc etc... I would wager that an otherwise stock ABY (if any still exist) would run better at WOT on the 3.8bar FPR as they would be a little bit leaner - makes more power unless it induces knock with a leaner mix (good fuel required) or of course that EGTs get so high that its detrimental.
                    • GT500
                      • Jun 2006
                      • 2181
                      Don't forget my RS2 on standard maps stuck the 561 code up and used far too much fuel all from the FPR being 0.2 bar too high. This was the original 3.8 fpr gone wrong. My ECU couldn't deal with the extra pressure so why will others be ok?
                      Rob..
                      87 UR 20v ABY
                      97 S6 Avant
                        I've done it without problems... dunno why your car threw up a code... could be a combination thing maybe with other variables contributing to it - like MAF or temp sensor out of spec (or on the edge).
                        • GT500
                          • Jun 2006
                          • 2181
                          Nope, all new.
                          Rob..
                          87 UR 20v ABY
                          97 S6 Avant
                          • s2avant
                            • 2426
                            Mine did the same when I was using stock RS2 software with the 4bar FPR. Fault codes, very rich running etc. Switched to RS2 3.8bar and it was spot on again.
                            Ben
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              I'm running the 7A FPR on my RS2 setup ofcourse this is a custom map.
                              But the main issue is that the RS2 FPR won't fit that easily on the 3B fuelrail where as the 7A fpr is a much better fit. I believe the RS2 FPR is integrated into the fuel line on the ABY and ADU.
                              Sleeper S2 Avant +450
                              A6 Avant 2.7t Stage 3
                              Audi S2 Coupe RS2'ed
