wgfv dead....or no power feed
  • andyg plym
    • Nov 2006
    • 4646
    almost managed to sort out my boost problems now and at least i have mechanical boost back, ive tried 2 wgfv and neither work,or at least no power to them. it used to clickity click all te time which reading old posts is normal, but now neither do anything.
    already checked fuses,inspected and cleaned wires,but nothing.
    dont have a multimetre to check resistance etc, so any other way i can check power to it?
  • andyg plym
    • Nov 2006
    • 4646
    anyone?
    • AndyP
      • 6049
      12v bulb and a couple of wires? Otherwise invest in a multimeter, they are invaluable and you can get a decent one for £25.
      • s2_bo
        • Oct 2005
        • 6067
        You can get a multimeter for about £10 from machinemart in Plymouth that should work.
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • andyg plym
          • Nov 2006
          • 4646
          im worried it could be more to it, i know i could test it but want to know wot other factors may be stoppin it workin
          • AndyP
            • 6049
            I had a bit of a falling out with the manager at our Machine Mart and now I can never return
            • AndyP
              • 6049
              Could be something simple like a broken wire, if you had a MM you could test all the wires for continuity.
              The UK's electronics specialist. Free UK delivery on orders over £35. Explore our extensive selection of tech essentials including batteries, cables, PC & mobile accessories, cameras, audio equipment, electricals, and security tech. Visit us today!
              • andyg plym
                • Nov 2006
                • 4646
                il invest at weekend!
                  Take the valve off and try connecting 12v across it, it should clickety clack like a mad thing. I use an old motorbike battery and a couple of thin bits of wire so if I accidentally short them together I wont blow myself up
                  • Faheemo
                    • Feb 2005
                    • 544
                    • Country: South Africa
                    Output Test from VAG COM will also click the N75 On and OFF repeatedly.
                    S2 Coupe fully built.
                    10.9 1/4mile 0-100 in 3.5secs
                    Precision 6262 turbo
                    The Green Monster
                    • Knight Rider S4
                      • 3541
                      I would put vag.com on it and go through out put test leave it on N75 test (this sends pulses to the WGFV to test its working via the ECU) while this is happening check every connection and wiring lead to the bulk head ..If you have a spare WGFV plug that into just to make sure the one you have on is working (if that makes sense)
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                      • Mikes2
                        • 1704
                        I've seen dead WGFVs twice on different cars and on both occasions it was wiring issues.
                        The wiring ends up at the ecu but there is a multiplug behind the headlight down in the depths of the loom. just before the plug, the wiring can be broken. Not sure if heat or vibrations / catching on the trims causes it
                        Mike
                        http://www.s2-audi.co.uk
                        • Knight Rider S4
                          • 3541
                          As this was the issue on my Avant ...we ended up fixing this at Errol ah?
                          93 S2 Avant Parting
                          91 URQ RR
                          02 A4 tdi Avant
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            You can run the output tests by connecting the diagnostic terminals as you would for the blink codes, but before you turn the ignition on IIRC.
                            SS
                            • Mikes2
                              • 1704
                              Yes, although somebody had been there already and attached one of the wires to ground.
                              output tests normally follow on directly after codes. If you read fault codes, you can trigger the output tests by jumpering the connector after the codes have finished
                              Mike
