3B breather system
  • sal_s2
    • 1287
    Originally posted by SteveH
    Sal,
    Drawn from memory...apologies if it isn't 100% accurate
    1a and 1b are the hoses fitted to the 3B motor
    Sussed it, 1b is the part I need.
    Thanks for the help
    • Floddy
      • Dec 2003
      • 222
      I have a "1b"-hose for sale. Bought it 2 years ago and used it for ~20k kms but now it's in the "partsthatIdon'tneedanymore-bin".
      Just give me a PM with a bid if you want it.
      Red cars are the fastest ones...
      - Team Irry -
      • jalmarsfar
        • Oct 2008
        • 3
        • Home: Sweden
        Originally posted by PeterS
        Gents:
        the 3B breather for the S2 is a bit different than on the 200 20v- the valve on the S2 is right over the crankcase, where on the 200 20v, its on the back of the head. On the 200, the last 6 inches or so near the crankcase tends to get mushy, collapse and split over time. Replacement is only available from Audi and is over $100 USD from the dealer. Has anyone looked into using the METAL replacement part that Audi made for the 7a (2.3 Ltr 20v non turbo motor)? its shaped like a doll's elbow. Saw this retrofitted on a 200 20v 3B
        Just an idea....
        -peter
        Where did you see this "retrofitted on a 200 20v 3B"? I cant find anything about it on the net =/
        • PeterS
          • 423
          It's a bodge but replaces the part on the rubber that tends to fail first. the last 10cm or so that goes into the crankcase..you will need to cut the old hose, slip the end over the metal end and keep it in place with a radiator hose clamp.
          Peter S
          1990 ErsatzS2 - track toy
          1991 Coupe Quattro
          1991 Coupe Quattro
          1995 S6 Sedan
          1995 S6 Wagon
          • WidowmakerS2
            • Oct 2007
            • 354
            • Current: Norway
            #20
            Sry for reviving such an old thread.
            Is the smaller hose going from part 1a vacuum?
            If at first you don't succeed, destroy all evidence that you tried.
            -CQ 3b "S2".
              No, it goes to the back of the cam cover.
              • auditude
                • 407
                Samco 200q20v replacement?
                On this old topic, is there a Samco replacement for the 200q20v breather hose?
                Kenneth
                1990 Coupe quattro
                1991 200q20v x 2
                1985 4ksq 20vt project
                1986 Coupe GT 10vt project
                2006 Honda Ridgeline
                1998 Honda VFR800FI
                • Chris P
                  • Dec 2004
                  • 145
                  #23
                  Roose make these breather pipes for the 3B now.
                  • archiboy24
                    • Sep 2003
                    • 286
                    From what I've read in this post, it sounds like a clogged breather system can cause fumes/smell to back up into the cabin while sitting in traffic. Is this correct? I'm getting an awful smell coming into the car, even with the windows up and the climate control off. Gets on my clothes too. Not a burnt oil smell but kind of what I expect the air from the crank case to smell like. A bit oily, a bit unburnt fuel, a bit like exhaust.
                    Ben
                    Calgary, Alberta
                    Canada
                    1991 CQ e//S2 w/ RS2 spec 3B 20vt
                    Panther Black Metallic
                    www.moda-architecture.ca
