Just doing a pressure test to make sure everything is running as it should as i had a few boosting issues since the RS2 upgrade. On my RS2 intercooler there is a little nipple on the side, i think aelred said it was for water injection. That is leaking pressure, everything else sounds fine. How can i block the nipple off?
3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
You might find that it's a screwey imperial size so perhaps re-tap and use a metric bolt instead. Apply a little sealant / threadlock / PTFE tape too so you can fit and forget
Other option is to get it alloy welded but doesn't sound like it's worthwhile here...
Ok thanks. Will a little leak like that make a big difference? My boost problems are, it will boost up to 21psi then cut back to about 5psi then take off again to 21psi?
Sounds a bit strange. Might be worth trying another ECU or checking the vacuum pipes inside the ECU in case they have been disturbed (although I'm sure Paul was careful it's still worth a look).
Any leaking vac lines could course that to happen, I would replace them all. If you want i can send you some blue 4mm vac hose as i just bought 5m of it and only used 2.
Jubilee clip a bit of tubing to the nipple then block the end of the tubing with a bolt and another clip.
If you want to pop round at some point Steve I'll show you which hoses are the ones to worry about. A small leak can cause a lot of trouble on these cars, mine had a leak where the vac/boost line joins the ECU, made the boost come and go, the car run rich and worst of all made my car slower than Andy's!
Yeah, the alpinweiss fleeced you along the Dunlop straight at Donny No chance now but then a) I'd have to get there and be fit enough to drive and b) you'd have to catch me
