Hi
Do Not run your turbo without a restrictor at all ! I think when this thread was started I was running a non ball bearing turbo from comp
I now run a a 3b ct 458 62 .63ar with billet turbine, best comp supply the restrictor as its very small check with them
. I will contact Comp for advise. Just sayin Bram did not use one.
