No Boost again
  • nikmay
    • Aug 2007
    • 112
    • Home: United Kingdom Current: Germany
    No Boost again
    While driving down the Autobahn the other day, (oh the joys ), my 3B popped a jubilee clip from the I/C to induction pipe, the one right at the bottom left hand side as you look from the front. Managed to bodge it to get me home, but since replacing I am back to mechanical boost only,
    Recently changed,
    DV tested seems to be ok,
    WGFV,
    MAF swapped for a known good one,
    Lamba sensor,
    all Vacum hoses and clips,
    all new clips every where in the engine compartment,
    Boost tested and no leaks,
    ISV
    plugs, leads, dizzy cap and rotor arm(from Toyota ).
    I do love this car but my saint abilities are wearing thin, looking for some more ideas from the people in the know, one thing I forgot my temp gauge is reading low could it be the MFTS.
    Nik
    All Hail the mighty Quattro
  • max_s2
    • Mar 2006
    • 498
    • Country: Latvia
    Have you tried to connect VAGCOM and read faults?
    • LHD_Kid
      • May 2006
      • 3696
      Did you reset the ECU after fixing the leaks?
      Just unplug the moteur fuses for a couple of minutes...
        LHD_Kid has it I think... The ECU has stored the alarm and disabled active boost control... Either clear codes on VAGCOM or pull the MOTOR fuses as said.
        • nikmay
          • Aug 2007
          • 112
          How long do they need to be out for, have pulled the fuses for ECU but still no joy, and dont know anybody around here with VAGCOM, even the local stealers suck through their teeth every time I turn up. think I will just go talk to her nicely.
            Use a LED and a wire jumper to pull blink codes - see http://S2central.net
            • nikmay
              • Aug 2007
              • 112
              Have tried mate but cant locate the plugs, even Bo said argh I remember trying to do this before when it belonged to Andy g and had no joy. They aint where they are meant to be.
              • WabTheKing
                • May 2004
                • 2567
                do a pressure test on the system to make sure another sneeky sneeky pipe hasnt slipped off, if you disconnect the battery overnight that should reset the ecu aswell
                • WabTheKing
                  • May 2004
                  • 2567
                  failing that book me a plane ticket+beer tokens and i will come over a vagcom the problem
                  cheers
                  will
                    Look in your main fusebox... you should have two eyelets in there with K & L connections...
                    • nikmay
                      • Aug 2007
                      • 112
                      Pulled the motor fuses last night and left it until this afternoon. Also went out this morning and totally rewired the MFTS. Took her for a spin and am now getting 1 bar of boost, she is now running as sweet as a nut, think I need to give her another pressure test to find out where the other .4 of pressure is going. Its true once you are bitten by these beasts you are in it for life, the good days far out way the bad days.
                      will keep posted as to where the pressure is departing to
                      Thanks for all your help.
                      Nik
                      • andyg plym
                        • Nov 2006
                        • 4646
                        nik, have you taken off and examined the accordian hose? i remember when i owned that car i had a boost leak for ages and it turned out to be that hose.
                        i have a brand new one here if you want me to send it to you?
                        • s2_bo
                          • Oct 2005
                          • 6067
                          The hoses on that car did look like they needed replacing when I saw you the other month. Maybe invest in a full silicon boost Hose kit and some 4mm vacume and some 8mm vacume for the wgfv and all the vac hoses.
                          Yeah the odb2 connectors ate defonatly missing. Being a 3b you'd expect them to be under foot well cover but they are no where to be sean. Even with ripping out half the carpets etc.
                          91 S2 coupé - RIP
                          98 S8 - Luxury barge
                          • nikmay
                            • Aug 2007
                            • 112
                            Think I will have to Bo. I have replaced all the 4mm and 8mm vacum hoses.
                            Will boost pressure test it tomorrow when I take it back into work.
                            • nikmay
                              • Aug 2007
                              • 112
                              Well I gave the old girl a boost test and there are no leaks anywhere, holds pressure for ages, what else could it be?? . Really dont want to take her on one of the ranges and see how much damage a 155mm shell can do.
