Changing my rods, what else do I need? I made a list!
  • Jonas_R
    • 3781
    • Country: Denmark
    What is the stem seals? I dont know that english word?
    Do you have a part no. for the second sump gasket? Or can you point it out in the ETKA link of the sump?
    I don't fancy buying anything that ain't from Audi since I can get it for almost nothing at the moment.
    /Jonas
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      I got the second gasket from Audi, so it's the same as the number you have, 074 103 609 F.
      I make the valve stem seals 027 109 675.
      SS
      • gedu
        • Feb 2007
        • 295
        Jonas, there are times when buying from AUDI makes sense, with gaskets, it isn't so. You get same Reinz gaskets from dealer (in Reinz packages to boot)... Somewhere else the same "set" will be cheaper
        All quattro products have been dermatologically tested, and are safe for daily use.
        • Jonas_R
          • 3781
          • Country: Denmark
          I'm not paying a dime for it, why should I buy it from somewhere else?
          • gedu
            • Feb 2007
            • 295
            #20
            Ah, sorry, forgot that
            • Jonas_R
              • 3781
              • Country: Denmark
              #21
              @gedu:
              Just to be sure, can you buy the Reinz gasket set from an Audi dealer?
              It is not that I don't appreciate the hint to get something cheaper. But if I don't get it from my audi dealer in Germany, then it won't be free and I will have to pay myself Which is something I really don't want to do.
              • gedu
                • Feb 2007
                • 295
                #22
                Well, they have Audi stickers on the Reinz package. So "OEM" pack is made by Reinz, and they don't seem to bother to hide it
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #23
                  Ok Jonas. Forget the Reinz numbers then.
                  Get 034 198 011 B and 034 198 012 M for the same block and head gasket sets, just with Audi stickers over the Reinz ones.
                  SS
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    #24
                    Do you by any chance now what these sets of gasket contains? Already ordered the gaskets shown in the first post.
                    • QuattroFever
                      • May 2006
                      • 1360
                      where do you put the thrust washers on these? in the center main of the crank?
                      Volcano ABY coupe
                      Ant
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        #26
                        Every gasket, seal and o-ring that is in or in contact with the head and block. I guess if you're not paying then there is no problem with ordering them all separate.
                        Here's the Victor Reinz Sets.
                        Block.
                        Head.
                        And here's an Audi Block set I found.
                        SS
