if the engine is loose theres no point in locking the flywheel over the normal crank lokcing tool - the whole engine needs restraining.
I'd use spink's method, but again I loosened mine before i took it out the car - even then with a 6 foot scaffold bar on the end of a 3/4" breaker bar I swear me and my neighbour almost lifted the front of the car off the ground doing it - if yours has been tightened to spec with thread lock and the proper torque and been on there for years I recon you're looking at well over 1000lbft to crack it off again. Good luck
Have you seen the ring gear on its own? I wouldn't trust it.
