MTM Stage II setup?
  • AndyP
    • 6049
    MTM Stage II setup?
    Can anybody tell me what set up is required to run MTM stage II 303PS chips? Things I need are:-
    Injectors?
    Fuel pressure regulator?
    Wastegate spring?
    MAP sensor?
    What boost should I be seeing?
  • GazzaG60
    • 4133
    thought you just bought a full good working motor andy.
    do you want to change it already?
    • GazzaG60
      • 4133
      sorry thats t2andy isnt it.
      id suggest after consulting repo and others along with my findings.
      1. standard reg is easy fine for that.
      2. id boost control or have it mapped on the standard spring.
      3. depends on the ecu setup. sure paul can help here. i got 4 bar in my vems.
      4. 1 bar on mine will see 300hp.
      imho mtm is old hat and the same can be got for less now unless you really want mtm.
      on a 2.5 id be going SC6057 full v band turbo for mid 2k spool and running to whatever but thats a 1200 dollar turbo.
      i doubt im helping here sorry.
        Injectors?
        Wastegate spring?
        MAP sensor?
        307 bhp should be achievable on stock ABY setup
        IIRC stock ABY setup will support 320 bhp on RS2 turbo
        • turbo s4
          • 58
          • Country: Belgium
          i run those chips in an s4
          everything stock
          289 pk last mai on the rollers
          tom
          • twoqu
            • Sep 2003
            • 3103
            Andy,
            Not sure whether he still has it or if you can get hold of him, but he might have some answers for you!
            Surely the biggest difference was the turbo (small RS2 upgrade, RS2 cold side, small K26 hotside).
            • Ian Simmonds
              • Jun 2005
              • 2858
              everything stock
              tom
              Ours runs StageII and ran out at an almost identical 290ps...
              93 MTMS2 Avant
              • europeanme
                • Oct 2005
                • 3817
                if only that were true...
                • AndyP
                  • 6049
                  Originally posted by twoqu
                  Andy,
                  Martyn has sold that car now, but it's still local so I'll try getting touch with him.
                  • AndyP
                    • 6049
                    Do you know if you still on a stock 250KPa MAP sensor? What sort of boost are you seeing?
                      Didn't mean turbo wise, K24 doing 300 is like the magical 4 minute mile.
                      I think Rusty will get there, if he threw in a 7A exhaust cam
                      • Ian Simmonds
                        • Jun 2005
                        • 2858
                        I don't, sorry Andy... The old girl hasn't been on a rolling road since 2003 when we got her and when that figure was generated... (My experience with rolling roads suggests it's probably +/- (more likely) 5% too)...
                        To my knowledge, the car is totally standard (even paper airfilter) apart from the MTM StageII remap.
                        93 MTMS2 Avant
                          @AndyP - if those MTM chips are not scrambled, I can have a quick look at their contents to answer those questions as it should be self evident to me unless they have completely munged the 'normal' Motronic structure but having seen inside MTM274PS chips for the AAN I'd be confident that is not the case.
                          As said above - I'd expect circa 1bar on redline for max power in 300bhp country and stock injectors on stock FPR should be fine and dandy. The wee stock turbo aint so happy running quite that much boost on the redline - so a good intercooler is required to keep air temps sensible up here.
                          • twoqu
                            • Sep 2003
                            • 3103
                            As I said earlier, pretty sure that they junked the K24 on this conversion:
                              Sorry yeah - that makes more sense alright - zee infamous 'small hybrid' again
