3b motor to 500bhp posible? without any problems?
No, no tach adaptor. I use an TurboXS (BC-HPBC) manual controller."Ring addicted"
8,43 BTG with trafic and roadworks:http://www.youtube.com/watch?v=pYg50Bg2lVQComment
Has anyone used the 034 High Output Coil with 3B ECU? Is it much of an upgrade to a (relatively new) stock coil?David
'91 3B S2 CoupeComment
The link isn't working but I believe it is this :Has anyone used the 034 High Output Coil with 3B ECU? Is it much of an upgrade to a (relatively new) stock coil?
I'm also curious about this, has anyone used this as a single coil on a tuned 3B, and with what hp? Have looked around but havent found anybody who has used it..Leif-Helge
-91 S2 VEMS and Comp Turbo
-12 B** 530XD Touring "S2 parts transporter, and daily driver"Comment
Take my apologize for old tread opening, but has anyone used this as a
(034 High Output DIS Coil w/Built in TTL Driversingle) coil on a 3B?
Thanks.Comment
Funny You should mention the Norris Evo.
Jonus Green 90Q (with 1065hp and distributor ignition) 6 wins - Norris 0 wins the times they met at Gatebil Rudskogen...
Norris always catces up at the end, because Jonus have to brake early before the righthander at the end of the straight. (Stock size brakes by the way) Still Jonus is 6 times first over the finnish line. Norris tried 2 years, change tires several times e.g. But Jonus was always first.
The 90q weighs at least 100kgs more than the Evo and still have the back seats in it. The Evo have trick dampers, sequential gearbox +++ Building cost 100.000+ GBP??
The Audi have stock gearbox, stock bushings, stock brakes+++
And you dont belive that it cant have 1065hp?? Just 0,3 seconds behind at 1/4mile with a building cost only 1/4 of the Evo and with a heavier car??
And dont get me wrong, the Evo is a realy great build and I absolutely love the car.
I just cant see have you can say that the Evos 927bhp is absolutely spot on and not "one trick pony" but doubt that the heavier and simple Audi can not have 1065hp??
1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
