Hi
recently i have started having issues with missfire as i ramp in boost to over 1.2 bar. previously its been fine and this started intermitently a couple of weeks ago. now its almost every run.
i have found if i ease it in its not as bad but that doesn't help.
yesterday i fitted some new plugs. denso IK24. i like to test items these have not solved the issue. im going to order some bosch ones to see if they help as im sure that will be one of the reply posts to use the proper plugs.
i have replaced the boots on the packs with new ones so they are good.
Whats next and how would you test to find the solution. or do i go 034 and hope for the best.
id appreciate experiences and solutions to try to build up a knowledge base on this area.
many thanks. if i can get it sorted today/tomorrow i may make the rollers.
