Turbo after run pump switch
This is a sticky topic.
  • Knight Rider S4
    • 3541
    Originally posted by iain1067
    let me know if you got them ok, they are from bentley aka american so things might be the wrong way for us over
    iain
    Iain could you email me this to please as i have the same fault .......
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • iain1067
      • 984
      sure do it tomorrow pm your email address
      Iain
        Question does it matter on the polarity of these switches as I've bought one with new connector but polarity is not indicated on it.
        • s2driveruk
          • 12696
          dont remember there being any issue on mine when replaced it, just plugged them back in and was fine
          1992 3b S2 Coupe
            I'll have to get a volt metre on the OEM switch and work out which pin is which
            • mcandmar
              • Apr 2004
              • 5118
              An alternative would be to use an after run switch from a 7A, its a little sensor mounted onto a bracket on the valve cover that monitors ambient temperature above the exhaust manifold.
              On my car the after run fan kicks in every time i park the car, sometimes can come on two or three times if its really hot. Downside is it can set off the alarm due to voltage drop when the fan starts.
              Part number is 034919369A, and according to ETKA its rated at 85c. I think its physically the same size as the S2 after run switch however i would still mount it externally on its bracket as per 7A setup.
              I am almost certain these are a simple on/off switch so it dosent matter which way around you wire them.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
                AAN guys do that mod, not to my liking prefer it coming of coolant temp, if it's an on off switch it shouldn't matter cheers
                • s2martyn
                  Banned
                  • Apr 2008
                  • 408
                  polarity is not an issue as its a simple on /off thermoswitch that is not in contact with any earths
                  • Smiley
                    • Jun 2005
                    • 329
                    As I want to try the FAE part rated 105/100°C i searched and got the vag no.
                    281 919 369 used in A80 '93 ACE 4cyl
                    '93 Audi S2 Avant panthero black, 412.000km
                    '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
                    '93 Audi S4 C4 Avant, 260Tkm
                    '88 Audi 100 Avant turbo 44Q
                    '84 Audi 80 quattro tornado red
                    • Smiley
                      • Jun 2005
                      • 329
                      Found one rated 100/95°C with same shape M10x1 2pin:
                      FAE 3581, Volvo 3435172-6
                      I don't know if this part opens or closes at 100°
                      • ifa
                        • Apr 2005
                        • 57
                        Closes at 100C. Im using this FAE 35810 sensor/switch. Works fine.
                        • A80Avant
                          • Sep 2005
                          • 10873
                          • Country: Greece
                          #27
                          it seems that i have lost the part number for that thermal switch i have used and it is rather difficult to see the number on the switch from the engine.
                          does anyone know how i can look for it in etka? i have tried but no luck so far...
                            Folks done this mod but the fan is running all the time with the ignition off at speed 1, any ideas?
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              #29
                              could it be that polarity thing?
                              have you tried put them cables in reverse?
                                There's not polarity it's an on - off switch that completes a circuit when I asked previously on the forum but I will try switching the wires around worth a go!
