right, here the thing, i would like someone to explain to me how/why the boost system works as it does, i understand how everything works from the MAF through the turbo - intercooler - xmember - silicon pipe - metal pipe - throttle body elbow - throttle body
I know theres an outlet to the wgfv and an outlet to the recirc valve and another to the cam cover breather in the pipe between the maf and turbo inlet and i understand why they are there apart from the breather to the cam cover, or is this a breather back into the inlet?
I think my main question is, how or where can the boost escape in or around the breather system?
I did a boost leak test earlier using the Andy P test kit, i used the 3 bungs, the one with the valve at the pipe the maf is usually plugged into, the other large plastic bung at the pipe that plugs into the metal boost pipe, and the metal one plugged into the turbo inlet hose where the cam cover breather plugs in. I compressed the system to 1.5 bar and heard a girgling noise like bubbling fluid of some sort!? Any ideas? Have i done something wrong?
When everything is restored, if there was no leak between maf- bung at the metal pipe, where could there be a leak? How would the breather system be seeing boost pressure?
Sorry for the babbling on, any help appreciated
