My car has been sat for about 2 months waiting for garage space to replace the clutch.
It failed to start a week or so ago so i recharged the battery and tried it again.
Its turning over but not startting.
I have fuel pressure and spark, although the spark seamed a bit intermittent when i tested each plug lead in turn. Sometimes nothing, sometimes they all spark
I also tested the coil lead that goes to the dissy and on a couple of orcasions it wasnt sparking, but most of the time it was.
I pulled out all the plugs and found a big puddle of fuel in cylinder 1 and 2, the other 3 where reasonably dry. This was after a good 5 minutes of cranking. The fuel rail was also under a lot of pressure.
I double checked all the timing and its all spot on so cant be that.
If confused as to why its sparking but not consistently and how there can be so much fuel deposit in 2 cylinders.
Can the G62 temp sensor stop the engine from starting full stop? And would it throw a code when the engine is off and only ignition is on?
I took of the dissy cap and found that the terminals were a little corroded. I have ordered a new one just incase its that but it doesnt look that bad, not bad enough to stop it from starting altogether. Besides there is a spark on all leads when they are checked in turn.
Can anything else be unplugged to trigger some sort of limp home mode to help it fire up?
I have tried MAF, ISV and WGFV so far.
Thanks in advance.
Bo
Thanks in advance.
Bo
