Howling noise from turbo and no boost
  • Jonas_R
    • 3780
    • Country: Denmark
    #61
    If your boosting 2-2.1 bar surely that could be the cause of the problem?
    Which kinda DV are you using? I used a Bailey once that was defective and it fooked a brand new RS2 turbo doing a mapping session. The DV was not airthight doing mapping so I ended up braking the axle.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • 220bhp
      • 2578
      • Home: United Kingdom
      #62
      DV is a standard OM S2 and it is working as I tried it on my s6 same with the n75.
      I agree that it is the highboost level thats killed the turbo, problem is what is causing the high boost.
      • 220bhp
        • 2578
        #63
        I have received the damaged parts back from CR turbos and I will try and take some pics to show the damage which they say is from over spin there are a list of possible causes, all of which I have already addressed with the exception of a possible fault
        within the ECU.
        The turbo is now back on the car and the car is running so to prevent this happening again I am taking the car to a specialist to find out once and for all what the problem is.
        • Algernon
          • Jan 2010
          • 79
          I've spoken to that chap I was telling you about Lou and hopefully he'll be talking to that bloke with the contact number you wanted.
          That's if you haven't got this sorted yet.
          • 220bhp
            • 2578
            #65
            Chears Allan I still have the same problem, look forword to hearing from him
            • Algernon
              • Jan 2010
              • 79
              Has he called?
              Any progress?
              • 220bhp
                • 2578
                #67
                Yes mate brilliant
                • 220bhp
                  • 2578
                  #68
                  Altitude sensor
                  Can anyone confirm that the altitude sensor of my s6 is the same as the one on my 3b
                  • twoqu
                    • Sep 2003
                    • 3103
                    #69
                    Yep!
                    853 919 562 fitted to 3B/ABY/ADU and AAN!
                    • Acidburn
                      • 13459
                      If you want one of these or are in need of any parts anytime lou give me a shout, i've got a complete engine/loom/ecu/altitude sensor etc lying around so if I can help out I will do
