Howling noise from turbo and no boost
  • 220bhp
    • 2578
    • Home: United Kingdom
    #46
    I have just heared from CR turbos,not good news ether the turbo shaft is bent with exstensive damage in side the turbo dew to they say overspin, £695 + vat to fix it. This is a brand new turbo and has done very few miles which they find hard to beleive so I have asked them to send a report on what might they think would cause this.
    In the mean time I gess its time to do a few sums and make my mined up on what to do.
    • GazzaG60
      • 4133
      so boost leak is a possability as i thought. id have a good check of all pipes and diverter and wastegate
      was the turbo primed before fitting?
      • 220bhp
        • 2578
        #48
        I have performed two boost leak tests and that includes removing all the boost pipes. After the first one[which found found no leaks] the second leak test was done after refitting all hoses with new clips,this included vacume hoses. I also changed the dv and the n75 from my s6 which ran fine on them.
        • GazzaG60
          • 4133
          strange one then.
          a mate had a so called recon unit for a volvo that lasted about 2 weeks. similar issues.
          • 220bhp
            • 2578
            #50
            I have had the turbo confermed as originl borgwarner.
            • urS6Tom
              • 773
              Sorry to hear about this
              I've just had a brand new RS2 turbo and manifold fitted so will be watching the post mortem with interest!
              • HMS-S6
                • Jan 2010
                • 1164
                #52
                I may be dismissed at talking rubish but, could it be caused by turbo stalling when shutting the throttle?? Perhaps from a faulty diverter valve not opening properly/enough maybe? Just a thought!
                  #53
                  Is the wastegate opening and shutting properly ?
                  • 220bhp
                    • 2578
                    #54
                    Wastegate has been of and all checked out working fine
                      Originally posted by 220bhp
                      The car has done about 450 miles since fitting these items and boost was very good in the begining, a little too good as it was over boosting/spike to 2/2.1ing in 4th and 5th
                      then cutting the boost then climbing and so on,it pulled like a train in first three gears,I have checked the wastegate diaphramby sucking on it and it appears to hold vaccum but could it still get stuck open,if so how do I check this.
                      This is what you said in an earlier thread.
                      • 220bhp
                        • 2578
                        #56
                        Thanks for the reminder John, the waste gate has been of the car twice now and has been checked for problems, its ok including the diaphram.
                        John I beleave you had an rs2 setup on a 3b did you experiance any problems in the early stages what was different about your set up to mine and what boost levels where you seeing.
                        • 220bhp
                          • 2578
                          #57
                          Can anyone tell me if the wastgate on an s6 is the same as the 3b.
                          • twoqu
                            • Sep 2003
                            • 3103
                            #58
                            Lou,
                            Some info here when John had some trouble.
                            I looked at this recently:
                            034 145 705B 3B
                            034 145 705E ABY/ADU
                            034 145 705B AAN
                            So it would seem that they at least share the same part number. Why the ABY/ADU has a different number I am not sure.
                            • 220bhp
                              • 2578
                              #59
                              Thanks for that Robin I will check this to make sure.
                              • 220bhp
                                • 2578
                                #60
                                I have now checked the wastegate and it is a 34mm s2 wastegate with a standard s2 spring. Also checked the travel and it is approx 16mm, not the 6mm that newsh had,the diaphram is also intact and working.
                                I just got the turbo back from CR turbos, they have done a fantastic job very impressed with there help and service, only problem is they forgot to pack there report along with the damaged parts but I should get them tomorrow.
                                My only problem is I still dont know what is causing the overspin as I beleave I have now checked just about everything.
