Stock pistons vs custom
  • Nik0las
    • 1345
    • Country: Bulgaria
    I have a dilemma! I'm after 500hp project and right now considering building the engine. I already got the rods but should I invest more money for custom pistons or stick with stock ones?
    Basically what are the limits of the stock pistons and what will be my benefits if use customs?
    what is the price of the bearings and segments in UK?
  • PeteUr
    • Jan 2010
    • 331
    • Country: Togo
    stock pistons will be fine for that power. - 700+ bhp is possible on stock pistons.
    Sapphire cos running custom 2.8litre conversion,es cos rims,raven black leather interior and 500+ with the gas turned off.
    Audi s2 cooking on gas
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      700hp are possible for oem pistons??
      • PeteUr
        • Jan 2010
        • 331
        • Country: Togo
        There is a blue s2 on youtube running 707bhp on stock pistons, i'm trying to find the link. I have seen one or two going as high as 800
        • repo
          • Dec 2004
          • 893
          Yes, only rings are not.
          I would consider aftermarket rings after 450hp.
          Well, haven't tried 700hp to be exact, but 650 ish in a couple of cases. Only issues with rings.
          • denniselbows
            • 740
            What make/type of rings would you sudjest something like total seal rings?
            never set your expectations to high that way you are never disapointed
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              and it is possible rebore a few in a machine shop and clean the cylinder bores for a nice engine block refresh continue later using the original used pistons with new racing piston rings??
              • JP
                • 1858
                If the bores are within tolerance once honed (correct piston to sidewall clearance), the pistons themselves have are not oval. Then you can fit aftermarket piston rings to original manufacturers dimensions. Pro Seal rings are nice rings for your hp target.
                UrS6 Stroker + HTA3586 =
                • repo
                  • Dec 2004
                  • 893
                  Totalseal would do.
                  Problem is, the skirt-wall clearance with old pistons is usually on high side. Especially after You hone the cylinders.
                  • JariP
                    • 192
                    If sticking with Kolbensmith/stock rings, is it better to go with chrome or moly top ring? Is it the chrome plating coming off the top ring the problem with stock rings?
                    • lind4hl
                      • Jul 2008
                      • 2465
                      Probably "Babek"´s s2 your´e talking about
                      • repo
                        • Dec 2004
                        • 893
                        Yes, it is the thick chrome that chips off and causes all the issues.
                        Original rings are made for longevity, not extreme performance.
