Did a test today driving on the highway to work. Made it up to lite bit above 700 degrees. Had the car running at about 200km/h fifth gear around +5k rpm, about 4-5 km. So I seem to be below the threshold
Well then I blew a hose/pipe coupling. It popped right off, barely made it to work after at pushing the hose all crumbled up in/over/outside the pipe (did not manage to get it on correctly)
At least I know what to do with my lunch
/Mike
. Well then I blew a hose/pipe coupling. It popped right off, barely made it to work after at pushing the hose all crumbled up in/over/outside the pipe (did not manage to get it on correctly)
/Mike
