Observe Track #14 - pin 3 from ECU is what activates the fuel pump relay... It needs to a specific type of relay here - not like on KV or 7A engine for example.
ECU pulls that pin to 0V so that the relay energises... then (and only then) should you get 12V at 87a, O and H87F terminals
Okay, we have starter power
Turned out the whole F-connector was loose.:mischeif:
Although I can't hear the fuel pump, there's def fuel in the system when I crank it.
I had a small leak in one of the hoses and a much bigger one near det filter.
Still won't fire up though..
If at first you don't succeed, destroy all evidence that you tried.
There's def fuel in the engine! Took out all the plugs today, and they were all wet. Dried them off and tried again, but still it only fires on one or two cylinders about every 10 secs.
Try reversing the wires to the hall sender? When I rebuilt my ur it would only fire weakly once every few seconds, the wire colours to the hall sender were wrong. Took a while to find that
