Interesting idea on the monster injector 'safe' map - presumably with a surge friendly boost profile as well. I would need a local car to play with - or cough for a set of 650s into mine to see how much pain is involved to get something running nicely. Do you really think there is much interest for that on its own just as an interim setup before custom mapping or is maybe more useful to have as a safe mode in a multimap ECU ?
E85 is a tougher nut for all the reasons you mention... The injector size issue can be worked around with higher fuel rail pressure but that aint ideal and is what I was eluding to about this not maybe being possible as a pure software upgrade - unless someone invents a software configurable fuel pressure regulator that you could interact with somehow. Way beyond my scope
I'm a bad influence at the best of times.
). The other car I like at the mo is Nip's car, something along the same lines but with a kkk26/7/9
and a few more ponies. GTs are great for power and are undoubtedly better technology but they can be fragile and seem to cause the odd problem with things like the breather system, bigger turbos are naturaly faster in a straigh line but 6 years' experience on here has shown that 350-400bhp is reliable on these cars for sure. That said, some RS2 turbos seem to have been right dogs... best to get them from a reputable source with a warranty.
). Not sure what boost is safe on the RS2 turbo but better to research that one thoroughly, hopefully 1.2 bar gauge is fine, it's the boost profile after that that will need investgation. Could be rather amazing if done properly, none of the factory lag of the RS2 spec and all of the 360+bhp capability of that turbo on even a standard car
