ecu upgrade
  • jorge s2
    • Feb 2009
    • 226
    • Home: Portugal Current: Spain
    ecu upgrade
    hello guys i doing some changes on the ecu , chips , as i dont have some large euros to expend i will do a small one , for now . the chips are from fastech , i will get 300 hp +/- . for now some pics of the ecu with the original chips its still a virgin jeje.
    audi s2 aby red 1993 powreded by prj
  • jorge s2
    • Feb 2009
    • 226
    • jorge s2
      • Feb 2009
      • 226
      now im going to take the ecu to welding the supports for the new chips , and tomorrow more pics whith the new chips , and some coments about the results , thanks , best regards
      • jorge s2
        • Feb 2009
        • 226
        ok guys i put the chips and the results are the expected , the car is very nervous but i 1.3 1.3 bar only and 1.4 1.5 in overboost is this normal?
        • BRY
          • 3755
          Don't know about the nervous bit but 1.4 on overboost sounds about right.
          • spions
            • Oct 2009
            • 400
            I have 1.9bar
            • jorge s2
              • Feb 2009
              • 226
              yes but if tue chips supose to increase 72 hp + 230 stock hp = 300 hp 1.4 its a bit low i think , or i dont have 300hp.
              • Smiley
                • Jun 2005
                • 329
                1.5 overboost is maximum with the 250kpa pressure sensor, cause you have to calculate boost + ambient pressure < 250kpa, so 1.5 + 1024mbar = 2.5bar = 250kpa.
                '93 Audi S2 Avant panthero black, 412.000km
                '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
                '93 Audi S4 C4 Avant, 260Tkm
                '88 Audi 100 Avant turbo 44Q
                '84 Audi 80 quattro tornado red
                • Smiley
                  • Jun 2005
                  • 329
                  Maybe your chip is aligned for a heavier WG spring, might be the reason for the 'nervous' boost..
                  • jorge s2
                    • Feb 2009
                    • 226
                    yes but if it gives 1.6 or more the ecu enters in limp mode but however the map should not limited the boost bars. right ?
                    • jorge s2
                      • Feb 2009
                      • 226
                      it could be im going to try with a hardest spring and maybe whith a forge 007. thanks
                      • jorge s2
                        • Feb 2009
                        • 226
                        Originally posted by spions
                        I have 1.9bar
                        yes but you have a 300kpa map right?
                        • Smiley
                          • Jun 2005
                          • 329
                          If you read more than 1.5 bar on your boost gauge ..
                          a) the ambient pressure (as mesured and reported to the ecu by the ambient pressure sensor F96 aka altitude sensor) is very low. Check your F96 if you haven't yet: http://www.s2forum.com/forum/showthread.php?t=31676
                          b) the pressure line to the ecu is not ok (if the line is closed somehow, the turbo may spin to death)
                          hope this helps a bit
                          • jorge s2
                            • Feb 2009
                            • 226
                            thanks smiley yes it helps, cheers
                            • Jonas_R
                              • 3781
                              • Country: Denmark
                              If your running stock K24 turbo then you will properly kill the turbo if you run much more then 1.5 bar boost. Also I would not expect much more then 280-290 BHP on a chip alone.
                              Sleeper S2 Avant +450
                              A6 Avant 2.7t Stage 3
                              Audi S2 Coupe RS2'ed
