Turbo upgrade with stock parts?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #31
    Originally posted by nip
    Im gonna be changin rods, due to goin bigger setup, i dont see the problem runnin upto or tad over 400hp on standard rods.
    the problem it is not the 400hp
    the real problem could be the 640nm of torque you got in your back with the k26/27
    i am runing much the same as you and 0 problems too (crossed fingers )
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      #32
      lol thats not the problem, i might even port and polish the head to see if there is any more mn to gain
      • Jonas_R
        • 3780
        • Country: Denmark
        #33
        Originally posted by rs200
        ok ...than don't change the rod... do remap on 400+hp... and live on edge...
        somebody will be happy because they will sale you new engine block and pistons...
        in Croatia we don't have much 2.2 20vt engines.
        4 x 200 20v
        8 x S4
        2 X S2
        2 X S6
        1 X RS2
        last year 3 engines blow away because we didn't change the rods... Aromatic is witness.
        good luck...
        Banana rods or what? I mean there could be other reasons for broken rods, ie preignition due to the distributor used on the 3B.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • nip
          • Apr 2006
          • 1786
          #34
          is there anyone one here who has actualy bent rods on a aby, adu
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            #35
            ..... dead silence and tumbleweeds rolling across the screen...
            1994 80E Avant
            1986 2L Golf 2 on Alcohol
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              i cant say nothing about it too.... i have a 3B but all my ignition parts since the battery , sparks,spark wires,distributor rotor , are complete new ,hope that continue working perfectly for dont broke nothig
              • hoffer76
                • Mar 2008
                • 230
                been trying to bend rods for long time now seen around 700nm but no bananas:mischeif:
                • fish
                  • Aug 2007
                  • 2333
                  • Home: United Kingdom Current: Sweden
                  #38
                  Originally posted by Billman
                  the RSR from MTM has had other rods if i remeber correctly. Also i dont think that MRC are selling a 650nm chip for the RS2 turbo.... i am not sure that it is possible.
                  If you look at the compressor map you will see that you can get 2 bar with the RS2 turbo but it decends wo the red line. If you have more than 1.2 bar on the stock RS2 turbo you are overspinning it and thus reducing it's longevity.
                  That´s odd, they boost 1,4 completely standard... at least all of my mates that have/had standard RS2,s have done...
                  Audi 80 Competition -94 Daily driver
                  www.garaget.org/fish for more pic´s of my cars
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #39
                    he means likely on the redline
                    • Billman
                      • 4129
                      #40
                      Redline of course!
                      Stock rs2 has 1.4 overboost and 0.9 at the redline.
                      Go Holset or Go RS4
                      • rs200
                        • May 2009
                        • 1398
                        • Home: Croatia
                        #41
                        for me ... it's real miracle that somebody drive 400 hp on stock engine..
                        in these 3 cases in Croatia 2 was 3B and 1 AAN engine...
                        my was stock 220 hp and have banana rods other 2 was broken on bearings and kick the piece of engine block out... now i don't wont to drive on stock rod even stock engine...
                        the rods are not the same in (3b aby aan adu rr) but all can hold same power or hp... now I go to rebuilt one more 200 20v and have one 3b and one AAN engine at home, but I don't wont to put engine inside the car because sill I don't have H rods. this car will be stock, but must have H rods.
                        maybe the problem is with 3b engine which have distributor and lots of misfire, but I suggest to everybody - use H rods. not so expensive 2 days of work, but means lot , and more...
                        • Jonas_R
                          • 3780
                          • Country: Denmark
                          #42
                          If the rod bearing fails surely h-beam rods wont help on that, the same goes for preignition.
                          • Jonas_R
                            • 3780
                            • Country: Denmark
                            #43
                            Also why do people say that 3b and aby/adu use different rods? Atleast acording to etka they are the same and i cant seem to any evidence that they where upgraded.
                            • Billman
                              • 4129
                              #44
                              apparently oldr engines had a 33 or EE stamped on the big end of the rods. This version is said to be stronger.
                              Go Holset or Go RS4
                              • Jonas_R
                                • 3780
                                • Country: Denmark
                                #45
                                What is older engines?
