SAFETY WARNING:-
The coolant system is pressurised when at operating temperature and so any leaks that go critical can cause an explosion of 90+degC coolant. If you're unlucky (and I was) you get this straight on your face and it HURTS A LOT! There's also the 3 hours in A&E to reflect on your previous good looks... I was lucky. If you think you have a leak, don't go poking about until the system pressure is released and the engine is off! This will make life a lot easier, trust me!
This is how I bleed the coolant system, had quite a bit of practice at this after my rad trouble a while ago:-
With the engine off and cold:-
You're now good to go but keep an eye on it for a run or two.
The leve shoulod be at min when the car is cold again and at max when at operating temperature.
Job Done
HTH
Update:-
If you have drained the heater matrix or pipework (e.g. when fitting a new block coolant pipe), then you will need to disconnect the engine to heater matrix pipe up by the strut brrace and back-fill the matrix / engine to prevent an air lock. On many cars, the plastic matrix bleed screw will have sheared, so you'll have to be a little creative to make sure that as little air is in the matrix as possible
- Fill the system and get the level somewhere close.
- Remove the 3 screws on the header tank.
- Lift the header tank well above the rad - you can sit it on the mounting points
- Undo the rad screw so that it lets any air out - when the bubbles stop you're done.
- Re-fit the header tank & screws.
- Fit the header tank cap on securely.
- Make sure the fan is connected - I forgot to connect the fan on more than 1 occasion, no harm done though!
- Run the car up to temp, keeping an eye on the level - if it suddenly drops then stop the car, top up to the min level then re-start the process.
- Make sure the fan kicks in at 90+2 notches - higer suggests a leak / not pressurising properly.
- Turn it off and let it cool - overnight if possible.
- Lift the header tank well above the rad.
- Undo the rad screw to let any air out - again, when the bubbles stop you're done.
- Re-fit the header tank / screws.
- With the car on level ground fill it up to the min marker (this must be done cold!).
- Repeat the header tank trick if necessary.
Job Done
HTH
Update:-
