Urgent: Anybody running Wagner EVO RS IC under stock bumper?
  • Jonas_R
    • 3781
    • Country: Denmark
    Well,
    I have a bit of problem here, the body shop that are fixing my car are telling me that the bumper wont fit over the Wagner EVO RS IC.
    So anybody out there running the IC under stock bumper that could tell me what they have done to make it fit?
    Body shop suggested to cut a hole in the lower part of the bumper, not the best Idea if you ask me.
    /Jonas
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    i dont meet none with oem front bumper + EVO IC...
    why dont you buy a fiber glass RS2 style front bumper??
    • Lupo911
      • Apr 2005
      • 312
      Originally posted by Jonas_R
      Well,
      /Jonas
      The IC works perfect with OEM RS2 and S2 Bumper, there is no cutting required.
      • madpugger
        • Sep 2007
        • 1901
        I think maybe the xm may be too low. The ic should fit under s2 and rs2 bumpers with no mods (except if you have mark h mod). Are you sure it's an s2 bumper and not a cab one?
        Le Mans 2012
        Nurburgring 700
        1995 S2 Avant
        • Jonas_R
          • 3781
          • Country: Denmark
          Bumper is S2 unless the body shop have ordered the wrong one.
          However I'm running with the mark H mod so maybe that is my problem?
          Carsten: The car you have fitted it on, is it with or without aircon?
          • Jonas_R
            • 3781
            • Country: Denmark
            Oki I guess it is properly the Mark H mod that is causing the problems then.
            Carsten can I use the stock O-ring or do I need different size?
              See is this thread helps http://www.s2forum.com/forum/showthr...=30455&page=12
              • Jonas_R
                • 3781
                • Country: Denmark
                Thanks Jamo that helped
                • Bram
                  • Aug 2006
                  • 2582
                  The Wagner EVO RS IC (that goes on the S2 traverse) fitted nicely behind my S2 bumper incl. the Mark H mod
                  • madpugger
                    • Sep 2007
                    • 1901
                    Yeah sorry, the Mark H mod sometime requires a little cutting of one of the tabs on the grille in the bumper, nothing major.
                    Try asking the shop for the part number of the bumper they got, maybe someone can post what is should be...
                    Le Mans 2012
                    Nurburgring 700
                    1995 S2 Avant
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      Bumper is S2 so will try and remove the Mark-H mod and adjust as much as possible to get it to fit
                      • Lupo911
                        • Apr 2005
                        • 312
                        Stock o Ring is fine... u dont need a Mark H Mod...
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Yep, same idea that seals a wiggins fitting the O-ring should be good to something like 200psi
                          Chef
