I am away to fit the following to my engine, so I was wandering what else I should do, such as, should I have changed pistons, used a different head gasket etc?
Stock ABY with Aronmatic rods
RS2 bearings
Stock head gasket
ARPs
Wagner reverse IM
Wagner RS2 Evo T3 EM
CT355 turbo
Siemens 630cc injectors
VEMS
Currently standard cams, but I may try find RS2 ones and get Repo to supply some adjustable sprokets.
So, should I have changed the pistons?
Should I keep standard pistons and a different Head Gasket?
What is the part number for Sport quattro head washers?
Any other advise?
I was also hoping to run E85 in the future, so it would be worth bearing in mind the extra torque and power that comes with that...
RS2 bearings
Stock head gasket
ARPs
Wagner reverse IM
CT355 turbo
VEMS
Any other advise?
