map sensor needed!
  • bigcooler
    • Jan 2009
    • 229
    ive checked all the pipes from the turbo to the inlet and theirs no leaks, so would that mean that the waste gate is leaking?
    • prj
      • Mar 2010
      • 6308
      How did you check for leaks?
      Visual inspection won't cut it most of the time, you'll need to pressurize it.
      • bigcooler
        • Jan 2009
        • 229
        i had some spare pipes in the garage and checked them all then made them fit from the turbo strait to the inlet manifold and still no difference.
        • bigcooler
          • Jan 2009
          • 229
          hi guys i would just like to tell you how much of a T**T i am, ive just been to hoffers and put it on vag com it came back with (inlet manifold pressure) so then rich rang his freind and its that easy to work out that he didnt even have to look at it
          It was the soft boost pipe that joins the inlet manifold to the hard boost pipe that runs along the back with all the sensors on it, the soft boost pipe had a split in it about 2" by 1" but it was on the bottom side so i couldnt see it
          im very sorry for wasting all of your time guys
          • Acidburn
            • 13459
            at least you've found the problem, thanks for posting up mate
