ive checked all the pipes from the turbo to the inlet and theirs no leaks, so would that mean that the waste gate is leaking?
map sensor needed!
How did you check for leaks?
Visual inspection won't cut it most of the time, you'll need to pressurize it.Comment
hi guys i would just like to tell you how much of a T**T i am, ive just been to hoffers and put it on vag com it came back with (inlet manifold pressure) so then rich rang his freind and its that easy to work out that he didnt even have to look at it
It was the soft boost pipe that joins the inlet manifold to the hard boost pipe that runs along the back with all the sensors on it, the soft boost pipe had a split in it about 2" by 1" but it was on the bottom side so i couldnt see it
im very sorry for wasting all of your time guys
