Engine block breather upgrade?
  • URQguy
    • Sep 2008
    • 245
    I am sorry. I missed the raised, baffled rocker on top of the valve cover. That looks like a great setup.
    I dont quite understand the question on the last sentense<dang english variations > but I am venting to atmosphere. In a closed dry sump situation, it would be vented in the boot with coming out of the pot. The stage would all be completely sealed and thus creating the vacume I would love. Some day i'll do it. For now, I'll put up the good fight with a labor intensive, but simplistic seperating system.
    I just dont believe that Audi ever intended to use that block port for breathing in motorsport applications. On even the meanest of 5 cylinders, 305hp isnt enough to cause the acceleration that would shoot loads of oil up the galley. I think we would find that Audi did away with that port in most race applications.
    1981 URQuattro with the TIAL GT35r.
    2007 Infinity g35
    • Rusty
      • 18953
      Need to look at getting a 19mm breather off the head. As alloy welding isn't something all of us do every day, I'll need to see if I can find someone locally that can do it.
      It will be interesting to see what can be achieved by a bolt on solution for more standard cars as we're getting into the realms of exotica (engines) on some of this.
      As before, I need to quantify the head oil usage on my car to understand the problem fully.
      • JP
        • 1858
        ^^^^ URUguy, yep cool that's what I thought, open system is to atmosphere, sealed is back into intake to pull vacuum.
        p.s. just read my question and it was a grammatical minefield
        UrS6 Stroker + HTA3586 =
        • URQguy
          • Sep 2008
          • 245
          Sweet. I dont feel like a dumb Yank anymore
          I dont mind the occasional atomsphere smell at stop lights, but my wife has a problem with it. I may try a valve of some sort to only plumb back into the intake<closed system> for those VERY rare times when she is in the car.. Like yesterday.
          2007 Infinity g35
          • andy10v
            • 5996
            Thanks for your input Hank, had a look at some of the piks of the underside of your rocker cover in your project thread
            Need to come up with a simple DIY way without all the welding though.
            Sold ABY-stock
            • Mcstiff
              • Oct 2004
              • 504
              I'd love to know if that riser fits.
              1995 1PissedOff90sigpic1991 USDM CQ 7aT
              • Thuppu
                • 4115
                Is it possible to use the AAN's valvecover stock breather in- and outlets for better breathing? If I drill holes on the connecting tube inside the cover and draw hosings to a oil separator/catch tank..? Hope you understand what I mean?
                • blackS2
                  • Apr 2010
                  • 455
                  [__]=oooo=[__]
                  • Thuppu
                    • 4115
                    Ok, great! Just like I was thinking it. Did u Black weld the breathing holes cover on it's place or how did you fasten it?
                    • blackS2
                      • Apr 2010
                      • 455
                      yes, it is welded at the black edding arrows... but care for camshaft space !
                      [__]=oooo=[__]
                      • Rusty
                        • 18953
                        Ooooh, that's neat init bey
                        • Herm
                          • Oct 2010
                          • 51
                          New to this but suffering the same messy problem on my car. Rusty im only down the road in Taunton if you need some ally welding done ? Will be making lots of functional parts for mine if I can be of any help ?
                          • Rusty
                            • 18953
                            Always good to have a local contact
                            • Rusty
                              • 18953
                              Head Breather Pip Investigations Thread.
                              • Thuppu
                                • 4115
                                Breather upgrade similar to blackS2's:
                                ...and a stainless diy oilseparator, needs only some polish:
