no power to ecu!
  • Tonks4x4
    • Nov 2005
    • 3062
    All the wiring diagrams are on s2central.net.
    Audi Nut!!!
    • QuattroFever
      • May 2006
      • 1360
      two wiring diagrams missing that i need to chase it back further.
      probably a long shot but has anyone got 27\6 and 27\2 for ignition
      Volcano ABY coupe
      Ant
      • johne
        • Apr 2007
        • 1405
        I've got both but as they came from S2central in the first place I can't see why they shouldn't still be there unless Paul has removed them.
        John
        • QuattroFever
          • May 2006
          • 1360
          elec. Windows are not powered too.
          Put ecu back in just incase.
          No joy yet.
          Bump
          Volcano ABY coupe
          Ant
          • QuattroFever
            • May 2006
            • 1360
            Not sure if its related but the airbag light has started staying on for an extended period of time when ign on.
            What the hell is going on? The wiring schematics must be wrong. Otherwise there would be power at motronic pin 27?
            Volcano ABY coupe
            Ant
            • QuattroFever
              • May 2006
              • 1360
              Can someone with an ABY check the ecu fuses on there car with a multimeter and see if they get power at the 15 and 30amp ones under the red cover when the ignition is on but not engine running? im starting to doubt that im even supposed to get power there.
              Volcano ABY coupe
              Ant
              • johne
                • Apr 2007
                • 1405
                Just checked my ABY. The beige fuse socket of the two which is the one with in my case a 20amp fuse in it and the one nearest the outside of the car always has 12 volts on it with the ignition key out or in the ignition on position.
                The 15amp fuse doesn't have 12 volts on it either with the key out or in the ignition on position.
                I'll have a look at my schematics and see if that makes sense.
                John
                • QuattroFever
                  • May 2006
                  • 1360
                  Im starting to wonder if the ecu finds a ground through one of the engine sensors which may be nackered. Sounds crazy I know but these cars have some strange things going on.
                  Volcano ABY coupe
                  Ant
