All the wiring diagrams are on s2central.net.
no power to ecu!
Originally posted by QuattroFever View PostCan someone with an ABY check the ecu fuses on there car with a multimeter and see if they get power at the 15 and 30amp ones under the red cover when the ignition is on but not engine running? im starting to doubt that im even supposed to get power there.
The 15amp fuse doesn't have 12 volts on it either with the key out or in the ignition on position.
I'll have a look at my schematics and see if that makes sense.
John
