...my stock car RR graph is with a boost leak created when the operator connected up their boost measuring pipe ...
Yes, as I said, it had a boost leak at the time, the overboost protection cut in on the dyno, it had been fine for an age before that - typical. I traced the problem to the pipe that had been used to T in the dyno boost measurement hose. Didn't do it again after that.
that was my point, hence posting the homefries graph in the first place but that wasn't mcuh help either. Good luck finding a standard one - I'm just askign a mate to see if he can help but it's a long shot.
Less boost there means less power, less AFR there higher boost means more power but more consumption.....one must choose!
Sorry, but this is wrong.
You do not make more power by upping boost and going too rich. At 11 AFR you are severely limiting power already... dipping to 10's is useless, you will not make more power, even with more boost.
Also, talking about consumption at WOT is useless. Consumption is important in transients and on cruise, not at WOT, because the car spends VERY little time at WOT.
I have swapped to std sw.
It runs around 12.6-12.9 for me at peak torque. Well, basically the graph is similar to homefry, except it does not go mega rich in the end.
I think there is nothing wrong with my car anymore. I ran really lean, because my breather pipes were not sealed tight and were leaking in unmetered air. Since that is fixed and all leaks are fixed, AFR's are much more solid and repeatable.
You obviously never lived in Germany.... :-)
As for the under 11.5 AFR speak to some guys with high powered cars with high boost and then you will see. Also in other car makes it is very common to run richer than 11.5 in full boost (i.e. Subaru).
Well, if you are going WOT at autobahn, then you should run rich enough, so that EGT does not kill the engine. Consumption is not important.
Look, you progressively combat knock with fuel.
You up the boost and richen the AFR to combat knock and measure torque.
But richer than about 11.1 AFR torque starts decreasing very fast. So there is no point to use more boost and go richer, you will not make more power because combustion efficiency decreases rapidly as the flame front speed decreases.
This is really the basics of tuning AFR, as is written in any book...
Some random guys who do not know theory and think boost = power do not change the laws of physics.
I personally agree with porkkis, that running richer than 11.5 is just stupid on these cars. If you are still knocking at 11.5, then dial back the boost and increase timing, and you will make more torque.
P.S. Feel free to try it on your car. Just try AFR at 11.5 and then at 10.7. Even with your butt dyno you will feel that the car has lost a lot of power.
That said, I personally try to tune to about 12:0 at peak cylinder pressure in cold weather. That way I have some reserve, so in hotter weather I can go slightly richer, down to 11.6-11.8 using a IAT correction table.
