You won't be able to raise boost 0.5 bar, unless you were running too low boost in the first place.
You can try to tune to 11.2-11.3 in hot weather and get it just right with a bit of leeway.
After that, if you go richer AFR, EVEN if you raise the boost, you will lose power.
Seriously, this is like really basic knowledge. You can raise your boost if you want, but you won't make more power dipping into 10's. Torque falls off _very_ sharply after about 11.1 (give or take).
