RS2.... knocking engine starting from 2500rpm
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    Hi all,
    Went for a ride this evening in my RS2. Warmed it up for about 15 miles, and after that I gave it some go for 2 or 3 times. A friend jumped in, we drove off, and we both heard a ticking/knocking noise around a steady 2000rpm. Drove a little further, and while accelerating you couldn't hear it, only just when gently stepping of the gas, or holding it steady. Didn't dare to go over 3000rpm, because then it got louder and gave harder knocks...
    Drove towards home verrrrry gently nog going above 2000rpm, and when I got home it had gotten a little bit worse. It knocks on just revving it a bit, and it still knocks badly starting from 3000 rpm.
    Idle is perfect, oilpressure and level OK, oil itself looks OK, runs OK. It has had a rebuild about 10.000 miles ago, with the big end bearings having been replaced.
    main bearings? bent rod? ...
    bad video, but you get the idea. The knocks in real life are more 'metallic'.
    thanks already!
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    could this be a lifter sound?
    • nip
      • Apr 2006
      • 1786
      • Home: United Kingdom Current: Abu Dhabi
      Originally posted by Avantus
      Hi all,
      thanks already!
      Check spark plugs sounds like 1 or more could be loose
      • Avantus
        • Sep 2007
        • 941
        • Country: Belgium
        All 20 were replaced with the rebuild, and the knocking is much worser than on the crappy video (have heard bad lifters, and this is worse). I don't dare to get put it above 3000rpm again, but i can asure you that it gets really hard metallic knocking.
        it gets the 'random' knocking like you can hear on this video:
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          oh yes spark plugs already checked, all ok.
          thanks for thinking with me all!
          • Ross
            • Aug 2005
            • 3399
            I wouldn't drive anywhere. In my Avant, i heard a noise like that for a matter of seconds before the bigend gave out, the rod snapped and the block was written off. Cause was a bigend bearing that had failed.
            • Avantus
              • Sep 2007
              • 941
              • Country: Belgium
              Might be better to call my mechanic and let him pick it up tomorrow.
              When driving gently with max 2000rpm (like i drove home with it for 15 miles) it doesn't make any sound however yet (at least not to be heard inside).
              better safe than sorry I guess
              thanks!
              • terrybullwon
                • Mar 2006
                • 8782
                If you could turn the motor by hand you will feel if its really bad.
                Chef
                • Ian Simmonds
                  • Jun 2005
                  • 2858
                  Our WR sounded almost identical to that, I convinced myself it was everything but the big end bearings....
                  And, I was wrong... No3 shells fell out the sump in 4 parts... Knackering the crank and the rod...
                  As above... Don't run it until you've dropped the sump pan to see what's happening.
                  See what I mean...
                  93 MTMS2 Avant
                  • Avantus
                    • Sep 2007
                    • 941
                    • Country: Belgium
                    will take that good advice, not starting it anymore
                    • GT500
                      • Jun 2006
                      • 2181
                      This was my noise, might help?
                      Thread here:
                      Rob..
                      87 UR 20v ABY
                      97 S6 Avant
                      • URQguy
                        • Sep 2008
                        • 245
                        Transmissions can sometimes make "knock" sounds that sound like engine knock. This probably is not the case, but get it on a lift and isolate the noise before you rip into it.
                        1981 URQuattro with the TIAL GT35r.
                        2007 Infinity g35
                        • Avantus
                          • Sep 2007
                          • 941
                          • Country: Belgium
                          Thanks GT500, good idea to have the oilpump checked too! On video it sounds pretty much the same. Did it also get even worse at higher revs?
                          My mechanic came this morning (what a service!) and he certainly thinks it's something from the bottom end.
                          When started cold it didn't do it for the first 20sec. I could rev it up to 2-3000 rpm without really hearing anything. Above 3000 it came back. When it warmed up a bit after a few minutes, it got back to like it was yesterday evening.
                          He's picking it up on monday or tuesday, and for starters he'll take off the sump and check play on the rods. I just hope the head doesn't need to come off.... just been done
                          Keep you guys posted, and thanks again!
                          • Avantus
                            • Sep 2007
                            • 941
                            • Country: Belgium
                            GT500, was your oilpressure still ok?
                            I had 1 bar on idle yesterday evening (oil at 90°C), but it climbed up ok till 4 bar when going to 2500-3000rpm.
                            Coldstart this morning was 5 bar, but I turned it off after letting my mechanic listening for a bit.
                            Possible that the oilpump makes such horrible metallic noises with still delivering ok oilpressure?
                            • A80Avant
                              • Sep 2005
                              • 10873
                              • Country: Greece
                              it should never be at 1bar
                              it should be at least at 1.8bar. on hot idle
