Finally i did it ,3B to RS2 setup dyno results
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    as tittle says...
    i am glad to see that the last dyno i tried worked well ,because i had 2 bad experiences before in one month.
    the first one was 307cv with 455nm¡¡
    and the second one 334cv with 502nm¡¡
    and now the last.... with 2 different ECu septups with of course 300kpa map sensor in each ecu.
    in a cold day i could have the 400cv¡'¡ and with the RS2 IC...in the future better¡¡ because i am runing with the small 3B original IC
    wich of both ecu setups do you like more?? the first with 391cv and 644nm? or the 375cv with 627nm with better topend power?
  • [RPM]
    • Dec 2009
    • 229
    • Home: Portugal Current: Ireland
    is it normal on a rs2 setup to loose so much power in the high rpm?
    is it due to the turbo loosing efficiency?
    best of luck
      Yeah its falling off realy quickly after 4.5k
      Here's my Coupe 3B , mapped by Mihnea March 2005. RS2 Turbo, IC, manifolds and injectors,
      Bosch Motorsport Fuel Pump, 7A FPR. Samcos.
      331BHP and 359ft/lb .. missing /holding back between 4 - 5k. (Can't remember how I fixed the misfire..)
      Not a brilliant graph but you can see there's a good spread between peak torque at 3k5 and peak power at 5k5.
        Are you still on stock rods?
        • T2Andy
          • 1903
          Is this a RS2 turbo or hybrid ,that's lots of torque
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            it is a complete original RS2 turbo,complete new
            but with 2.0bar in 4th gear and after 5000rpm loosing bost quickly to 1.5bar ,holding it to 6500rpm
            maybe with the RS2 intercooler i could hold more power and torque??
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              yes my friend, the engine´s internals are complete stock
              but of course my clutch it is upgraded : spec stage 3+ for 450hp and 700nm
              and i am using a gearbox from the coupe quattro 170hp with the ARv gearbox driveshafts
              • T2Andy
                • 1903
                It maybe running rich after 5000k which looses you power like mine does but good torque
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  i think that not,as the they said me. they did a Lambda dyno test too for see the values and they said me that everything it is Ok
                  and later in my Wideband gauge with full boost in 5th gear 2.1bar i see 11.2/ 11.3 AFR
                  • Rocco
                    • Aug 2007
                    • 6393
                    • Country: Spain
                    with a custom ecu setup it is possible keep 1.8bar at redline??:mischeif:
                    now i only got 1.5bar redline
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      Don't think that is possible, I believe the turbo will explode
                      Sleeper S2 Avant +450
                      A6 Avant 2.7t Stage 3
                      Audi S2 Coupe RS2'ed
                      • Jonas_R
                        • 3781
                        • Country: Denmark
                        My Dynoplot for comparison. That was with 1,7 bar peak and 1,4 bar redline.
                          I think max for an RS2 turbo at redline is 1.4Bar ?
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            they are very different true Jonas?? why??
                            the tuner said me that my car shows the power like a rally car...Full boostttttttttttt
                            i have to make the gear changes by 5500rpm and then i am again in 3800 with 330hp
                            • T2Andy
                              • 1903
                              Was the 5th gear done after 5000k at wot then you would be doing 140 mph +
