Most of you on here have seen me rattle on endlessly about my S6 which refuses to pull correctly whatever i change (and believe me, its EVERYTHING!), but today i may have made a breakthrough.
I thought the knock sensors were retarding the timing, but after buying new (no difference) and then running the car with them both tied out the way (not a good idea i know) i finally ruled them out!
BUT.............If i start the car THEN with it running unplug the crank position sensor (which is also new!) the car pulls spot on - the fastest its ever been
I know the sensor is ok, but does anyone have a clue as to what it points to?
I am told that it uses a 'memory' position from cranking in order to run.
